Hey Guys,
Me and my mates have a little bit of trouble understanding this.
If you are in 4th Gear doing about 50km....your revs are at about 2k right?
Why is it, that when you plant your foot on the accelerator...boost comes on straight away....
I mean the car doesnt move..but there is a boost reading of 7 psi with a stock R33.
Just wanting to know the EXACT reason why this happens....
Thanks
Stel
https://www.sau.com.au/forums/topic/92338-boost-in-4th-gear/
There is more load (resistance) on an engine in 4th gear than in the lower gears. The more load an engine has, the more exhaust it produces. The more exhaust it produces, the faster it spins the turbine. The faster the turbine spins, the more airflow the compressor produces. The more airflow the compressor produces the higher the boost potential
Remember that boost is simply a measure of resistance to airflow, not a measure of the airflow itself.
:D cheers :)
in an R33 full boost comes on by about 2,500/3,000rpm..
this is to do with the volume of air and the load that is going through the engine.. the higher the volume the quicker it will spool the engine up..
for a turbo to get going the engine has to have a fair bit of load on it so that the air will spin the turbo up to a high enough RPM to create boost which isn't till about 20,000rpm..
this is why in 1st gear you won't tend to make much boost as the volume + load isn't for a long enough duration to really spool it up till higher in the rev range..
by putting a higher load on the engine the car will dump more air + more fuel to get it going.. this air is what spins the turbo as it comes out - higher flow of air will spool it up quicker..
hope that helps.. probably not the best description..
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
