  • Replies 66
Went in this morning. It could possibly be done by today but since I rather have it running perfectly without any skips or beats to it, I've said they can have it for another day for it to be tuned properly.
If it is all good by the end of today and I can pick it up this arvo, I'll be happy!
You'll be surprised with Milanco then. Last time (which is the first time) the car was in their workshop. They said they'll have it ready for me on Friday afternoon for me to pick up. They then rang me and said it'll be done by the next day (the next day being thursday).
They rang me back again on the wednesday, said they had a few problems with the turbo cause it didnt fit, so they lent me a turbo for the duration of the time my turbo was in sydney being rebuilt and high flowed.
Thursday afternoon, I was able to go to the workshop and pickup the car and drive out without any problems.
Although these guys DIDNT have to lend me a turbo, they've actually done alot more for me as a customer/client then I've expected and with the care they've put not only into my car but also into the business of having me as a customer, they've done a hell of a lot better then Hardcore!!!!!
I dont usually recommend workshops to anyone but thats probably based on the amount of problems workshops have had. But Milanco have done far better then any other workshop I've been to and they are highly recommended by me.
Even still, I drop my car off at the workshop at 7.30 this morning and Brock was more then happy to quickly give me a lift up to the train station so that I could catch the train to work.
Now that is also good customer service & care!
News is....
BOSCH 044 fuel pump will not fit in the fuel tank as it's 13mm to wide.
Not surprised.....isn't the 044 an external pump and the 040 internal?
Pictures of the turbo rebuilt & high flowed taken by Milanco for me.
Of course, the cleaner one is mine compared to the turbo that was running on my car while mine was off getting rebuilt & high flowed by GCG.
Edited by r33skyliner
lookin for over 300hp or hopefully around the 240-260kw mark.
Cant really do much right now.
If i boost it up more with the new Apexi AVC-R that's in it, it'll ping.
Once the intercooler is on, it'll be fine to boost up.
But need to really upgrade the ECU they said.
phase #2 is a FMIC (600x300x76) hybrid style one and also a new front bar for the fitting of the FMIC.
phase #3 will be of course the ECU upgrade.
Get a PowerFC, you won't be disapointed. Going alot cheaper these days (Group buy on this forum & www.Nengun.com are selling them at good prices also)
I have just about finished my engine mods & got good results so far.
- New Garrett GT30 BB Turbo (500HP)
- New HKS cast manifold
- New HKS copy 50mm Wastegate & screamer pipe
- Apexi GT Spec FMIC
- Jasma 3.5" Exhaust (soon to arrive is a Greddy/Trust 4" titanium system
- K&N Pod filter.
- New Nismo 550cc Injectors
- New OS Giken Twin Plate clutch
- New Apexi PowerFC
- New Splitfire coils
- New Z32 AFM
- NewBosch 044 pump & surgetank in the boot.
- Blitz Dual SBC (electronic boost controller)
Result 285rwkw@20psi. I currently am using a 10psi wastegate spring, once I change it over to a 14.5 or 15 & put the new exhaust on, I should hit 300RWKW.
What Injectors are you using? & are you using a Z32 AFM?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
