Hey is it just me or has Speed Magazine disappeared from the face of the Earth? I haven't been able to find it for like over 2 months now, and I've looked in several news agencies that used to stock it. What gives?  :rolleyes:
"They taste like burning!."
Speed magazine ceased production months ago
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1665968
NOOOOO! (In case you couldn't tell, I acually liked this magazine!) Well at least I wasn't subscribed to it, and ACP didn't send me copies of something like Cleo to make up for the rest of my subscription. Just like the last time one of my subscriptions ran out. What happened, they went bankrupt or something?
"They taste like burning!"
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1666033
Never really read it before. What was wrong with it? I just never bought it because it looked too (how to put this...) um... well, if a magazine cover could protray an overly large ego and love of ones self, that is the impression i got from that magazine. It had an air of "i am the best magazine in the world i am awesome" so i never bought it.
So what's the story? Why does no one like it?
EDIT: I think it took itself too seriously...
Edited by Big Rizza
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1666121
Nah its pretty hardcore... lol. It has some ok content. some nice girls and some cars but its pretty full of itself.
that was the reason i bought speed it was more informative more mature and it didnt have to use chicks to fill the pages
it was a no bullshit all rounder performance mag
P.S in not gay dont get me wrong i love chicks lol but thats why i buy ralph it doesnt really need to be in a dedicated car mag
Cheers
Matt
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1666770
i subscriped half year and for 4 months just received one issue.and some days ago i received a letter said i can choose motor, 4x4 or ralph...
Motor is always a good read, so go for that. Last issue had reviews of BMW M5, Aston Martin Vantage, Pagani Zonda and many other great cars. They love their exotics.
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1667068
Cheers
Matt
Agreed
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1667389
Thats cause it's target audiance was older. It was for people that can afford GTR's and mod them to decent levels. unlike hot 4's and other excel moding publications....
It's not that it took itself seriously or thought they were the best mag out, it was just aimed at a more mature audiance.... plus i found there to be plenty of humor in there... see back page comparisons...
EDIT: and as with the post above mine.... my g/f actualy loved reading it too as it wasn't filled with half naked chicks... we have internet for that people!!! :lol:
Edited by Archie@
https://www.sau.com.au/forums/topic/92383-speed-magazine/#findComment-1667421
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
