G'day, tried running a search and got confused.
Quick question, I connected my brothers laptop to my R32 '89 gtst skyline running a diagnostics program (pretty sure its consult). When it is connected, the laptop cannot connect with the ecu, my brother tells me that '89 skylines are not capable of using the consult as they do not have the on board diagnostics or something similar.
Correct?
The laptop has only been used on SR20's and SR20DET's, does there need to be anything different for the RB engine systems? Or is it the fact that my car is incompatible?
Cheers
Edited by GTAHH
https://www.sau.com.au/forums/topic/92384-ecu-question/
If you have the plug under the dash then you can use it.
You are right though, the early 32's, some were unable to be read due to the fact they did not have the plug.
Cheers,
The plug is there above the fuse box, when the laptop is connected it cannot connect with the ecu.
Any takers?
https://www.sau.com.au/forums/topic/92384-ecu-question/#findComment-1667698
Well, my '89 Skyline was able to talk to the Nissan Consult.
Silly question - You do have the factory ECU (not a PFC or similar)?
I guess ill have a look, I just bought it off a guy who imported it and haven't really looked through the whole car yet.
Maybe it needs to be set up differently to work on the RB?
https://www.sau.com.au/forums/topic/92384-ecu-question/#findComment-1668201
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
