  • Replies 44
Yeah that video is old. There is a direct link for that video in mpg format on Openwheelers.com. They also have the 5th Gear Review. The Arial Website also have many other Magazine Reviews for download.
Top Gear have all sorts of interesting toys on their show. I think my favourite from the show would be the Vandenbrink Carver, and the custom made cars from Rinspeed (including a hideous Porsche 911 ute).
As for the Atom, the car is a bit irrelevant to us in Australia since I can't think of any way you could get one on the road.
I would also like to congratulate myself on making every second word a hyperlink.
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1666230
thnx for busrting my bubble :D
i thought it was new, did a search and not many ppl have mentioned it
Hahaha, sorry dude! I'm a bit of a Top Gear nut, so anything more than a few months old is "old" for me. It's a good review though. I think they should have chosen an R1 or GSXR1000 or something rather than a 600cc bike to race it against though.
If you like your top gear (or fifth gear), check out Final Gear, they have heaps of stuff there, including recently added classic episodes from 1989 and 1990.
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1667039
There was a story about the Ariel Atom on Beyond Tomorrow last night, they were saying that we should be seeing these on Australian roads 2006/2007 so don't lose hope yet. B)
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1669380
If you havent seen this car it is freaking amazing.
I saw it on TV last night & they're hopefully going to be street legal in Aust by 2006 but currently arn't road worthy 'in Aust'. Gezzz they'd be a lot of fun.
Here's a few links
Info
Video, So so quick...0- 100mph
MUST SEE THIS VID
Top Gear Video review 'After watching that vid my skylines feels so slow already...
I've always wanted a race car & this will be the cheapest & fastest race car expience out there! Hell you can even take your mate out on track days!
Edited by geno8r
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1671010
The lovely chaps at Open Wheelers Australia are looking at getting these things complied under the low volume import laws (so they don't have to crash test them).
From what I've heard, they should have it sorted by year's end.
There have already been drive days with these things available. Don't think the S/C one is available, but the NA ones were.
I've been giving some serious thought about getting one if they come out. I've already convinced myself that I can live with an Elise; its only a short jump to a car with no bodywork.
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1672318
U can get em imported trhoguh NZ today if uve got about 70k for a base and 90+ for the k20a with blower in it.
And for the record its a type s motor :D type r was 1.8 ltr
Riiiight.
You apparently own an Integra, but clearly know little about its history.
Edited by scathing
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1672346
Same, once they get into Aust 'the S/C version' & prices are set I think I'm going to set some goals '& a loan B)' & consider getting one. I mean, they look like incredible to drive, extremely fast, handle like an Enzo.... you buy one of these for pure driving pleasure & that's what I want. Even if it wasn't road legal I'd still want one just to drive on track & I'm sure there'll end up getting their own race class, what a hoot!
https://www.sau.com.au/forums/topic/92388-ariel-atom/#findComment-1673222
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
