my parkers and my dash lights are ALWAYS on i cant get em off...
anyone help?
i do have some guages wired up n they are always on too.... only really want them on when my lights are on :\ i think i might have crossed some wires somewhere... anyone know which colour wire is for the lights n should be wired up to which wire etc. or should i jus see a auto electrician
https://www.sau.com.au/forums/topic/92428-parkers-dahs-lights-stuck-on/
It sounds like you've hooked your gauges into a constant power supply....
with my gauges i hooked them into the back of the cigarette lighter.. so it lights up when i turn the lights on.. i think there was just a red and black wire, stick her into the red wire...
You could also hook it upto the thing you stick the key in, or anything realy that turns on when you turn the lights on...
Which model Skyline do you have? I know in the R32 there is a push switch (probably for fog lamps) next to the main light control switch - you haven't accidentally pressed that one, have you?
