Do a burnout. If both wheels spin up you most likely have an LSD. If it's a one legger it's an open diff. :D
EDIT: oh you said without doing a burnout, my bad - You could also try driving around in circles with too much throttle to see if you can spin up the inside wheel.
Edited by Big Rizza
https://www.sau.com.au/forums/topic/92433-lsd/#findComment-1667206
Doing a burnout wouldn't really tell you if you had an lsd anyway. A mate of mine was convinced his VT commy had an lsd cos it always got both wheels going.
But it didn't, just a standard diff.
I think the code/part no. on the diff should tell you. Look it up in a manual for that car, it will tell you what code is for what diff.
https://www.sau.com.au/forums/topic/92433-lsd/#findComment-1667683
  ruffryder said:
if it was open diff, which wheel is usually the one powered anyways? is it the right one or does it depend on which model it is, i.e. r32 gts/gtst, r33 gts/gtst, etc.
The power goes to which ever wheel is easier to turn. So in normal driving it will go to both wheels just like an LSD. In tight cornering it will allow the outside wheels to turn more than the inside wheel to prevent the back end skipping (which happens in very tight or locked diffs). But if one wheel starts to slip with an open diff, that wheel will be easier to turn and hence will get all the power. An LSD essentially doubles the traction because you need enough force to spin up both the wheels rather than just one (not quite true, but you get the idea).
On an aside, Ferrari claim their new E-differential is so good that it gives their rear wheel drive F430 as much traction as a conventional all wheel drive system (for example in the Lamborghini Gallardo) in all conditions except snow. But Ferrari claim a lot of things...
https://www.sau.com.au/forums/topic/92433-lsd/#findComment-1688145
The Ferrari E-Diff is an active diff, like the M's Variable M Differential Lock. Both trumpet them like they're the next coming, but all I can say is "Welcome to 10 Years ago".
The Prelude VTiR ATTS had an active LSD well before these two. The Ferrari and BMW one might be more advanced, but Honda released theirs in 1997 in a $50K car.
I'm pretty sure the EVO Lancers have had active diffs since the VI as well. Now I wonder how much traction a 4WD car with an active has in comparison with a 2WD car....
https://www.sau.com.au/forums/topic/92433-lsd/#findComment-1689036
You can get LSDs on FWD cars. The 80's Pulsar SSS's (post ET Turbo, pre N14) used to have viscous LSDs in the front.
They're even less common in FWD cars, since they tend to be econo runabouts that people don't buy for sporting pretensions, but they're out there.
All the Honda Type-R's run LSDs. A lot of the journos lament that the new Type-S has lost the LSD, which means they can't punch out of corners with as much traction as they used to.
The FTO runs an LSD. The RalliArt Magna actually uses it in its application, which at least lets you know the FTO LSD will handle a major increase in torque.
https://www.sau.com.au/forums/topic/92433-lsd/#findComment-1694334
Only on the Version R or Limited Edition (Yellow) GPX FTOs :D
https://www.sau.com.au/forums/topic/92433-lsd/#findComment-1694757
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
