Garage Sale - I Need A New Clutch Fund
*****NEW ITEMS ADDED*****
GTR Exhaust (Stock Cat Back) - $150
BMX (old school- very average condition) - $50
Turnatable (omnitronic) - $300
2 Channel Mixer -$100
Alloy GT Wing - $250
Stock R32 Intercooler (with piping) - $200
Stock R32 Air Box - $100
GTR Front Splash tray - $75
Incar Camera Mount (Bar between the seats, no actual mount) For R32 Gtst and gen 3 honda Prelude - $25 each
Integra/Prelude Boss Kit (requires slight modification for prelude)- $65
*****Stock R32 Muffler -$Make an offer
*****Nissan Wallet - $25
*****Honda Prelude Gen 3 Wheel Caps (4)- $80
MY HOCKEY GEAR
*****Bag o wheels -$35
*****Mission Skates - see pic for details - $100
*****Mission Gloves - $70
*****Mission Helmet - $50
*****Elbow guards - $25
*****Shorts - $15
*****Mission Pants - $60
*****Mission Shin guards - $80
*****BMX gloves - $15
Assorted basketball cards - most 50cents each, higher end/rare cards only $2-$5
REMEMBER ALL PRICES NEGOTIABLE-EVERYTHING MUST SELL
More Items will be added soon.
Edited by Black R32
will be getting pics of everything soon. the camera mount is just a light weight bar that the holes are drilled to fit exactly between the seats. you just take the head rests out. put them through the holes and put the head rests back on. very stable. no actual camera or tripod top included.
The splash tray, i haven't really looked at it that hard so i couldn't tell you what condition it's in. will look at it and take pics this weekend.
Edited by Black R32
Does anyone collect basket ball cards? going through all my old stuff i had stored in boxes and found sets of basket ball cards, couople of comics, football cards. blah blah blah. Will be putting everything on ebay soon
will have pics of wallet and mixer tonight maybe.
Splash tray has a couple of scratch marks i think but a couple of the holes are broken. only hada two second look at it.
Make me an offer on all items. Clutch is on it's way out.
Edited by Black R32
SPLASH TRAY
MIXER (sorry, little dusty)
NISSAN WALLET
R32 STOCK MUFFLER (virtually straight through)
CAMERA STAND (Top one skyline, bottom one prelude. doesn't come with mount)
NOW ONLY $25 EACH
GEN3 HONDA PRELUDE WHEEL CAPS (4)
STOCK R32 GTST AIRBOX
Sorry about the big pics
Edited by Black R32
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
