|PRESA| Posted October 25, 2005 Share Posted October 25, 2005 I've got a set of 740cc Nismo injectors for my RB25.. Is it recommended to leave these to the pro's to install or can it be done safely and successfully by anyone mechanically minded?? The injectors do not include the o-rings so how would I know what kind of o-rings to order and what compound? Also I'm planning to get the injectors flow tested before installing just for safety reasons, anyone know where I can get this done (preferably S E Subs - Vic) and how much?? Link to comment https://www.sau.com.au/forums/topic/92473-installing-nismo-injectors/ Share on other sites More sharing options...
GTR32 Posted October 25, 2005 Share Posted October 25, 2005 have you got a programmable ecu, if not don't do it because the thing won't run. the standard o rings should fit fine. not a big job just fiddly, plug clips go flying etc and for what a mobile injector van charges i reckon it's worth it to get one in. they will probably have o rings too if you need them. Link to comment https://www.sau.com.au/forums/topic/92473-installing-nismo-injectors/#findComment-1667811 Share on other sites More sharing options...
Abo Bob Posted October 26, 2005 Share Posted October 26, 2005 The hardest thing is getting the 3 bolts underneath the plenum out. I tried to get the fuel rail out without removing the top half of the plenum and it was really close but couldn't do it. You need a slim fit socket and short thin extension bar for it. Apart from that pretty easy. Link to comment https://www.sau.com.au/forums/topic/92473-installing-nismo-injectors/#findComment-1668207 Share on other sites More sharing options...
Bass Junky Posted October 26, 2005 Share Posted October 26, 2005 |PRESA| Talk to Speed Technology about flow testing the injectors. 9873 5400 Link to comment https://www.sau.com.au/forums/topic/92473-installing-nismo-injectors/#findComment-1668568 Share on other sites More sharing options...
|PRESA| Posted October 27, 2005 Author Share Posted October 27, 2005 Excellent thanks I might leave it to my tuners to install but in the mean time I'll do a flow test to make sure they are all fine. Link to comment https://www.sau.com.au/forums/topic/92473-installing-nismo-injectors/#findComment-1669938 Share on other sites More sharing options...
