hey guys,
just received my PFC today and wondering where's the best place to tune skylines in W.A .....Mine is a GTT R34, dun think the car model make any difference..
ahh also exclude X-speed lol they are too expensive for me...I asked they charged like $800 + dyno....lol
I was told Evo R or top racing...
https://www.sau.com.au/forums/topic/92481-where-to-tune-pfc/
Hyper is in Malaga Vale St
Xspeed is Zeta Crs Occonor
Chipmaster is somewhere in maddington I think
once again, dont be stupid enough to go elsewhere :)
oks it's decided I'll go auto master tune my car :P
Hyperdrive sounds good...how bout gfx or whatever I saw this white R34 with groundeffects dunno what the heck that is but sounds like tuning company
sky34 where ever you go make sure they have a datalogger for your pfc as it will save a lot of time on the dyno $$$$ and where and tear on the car
without datalogger a lot of companies quote 5 to 6 hours
with datalogger at hyperdrive my first tune took less than two
thats a big different in $$$ at a $100 plus an hour
pete
Sometimes what you pay is what you get. Let's say you go to someone who's not so good, you might have to go back multiple times as they can't seem to tune your car properly. So in the end, you pay more than what you thought you'd do.
A common case back home where i'm from. Take an evo 8 with motec. 3 times into the workshop for a dyno tune, each costing $400 couldn't settle the problem. 1 time at a more reputable workshop and with $900. Everything is settled and good to go. If he had just taken the more exp way. He'd save 1.2k. But of course there are always problems. Even the best of dyno tuners do run into a wall once in a while, so you can't really blame them. It's an art.
Oh yeah, there's an idemnity form if you didn't know, so if they blow up anything in your car, they arn't liable. And if your tuning is bad .. well they always tune it rich cause it dosn't blow ur engine as opposed to lean.. then there is a possibility that your engine will blow too. Factor all these in before picking out a place.
Just my .5 cents worth. :P
Basic R34 with PFC is an easy job most tuners can handle in a few hours max.
Yeah, agree with that. Hahah, my friend had a jun cams, forged pistons, Some aftermarket turbo i think a GT30R? But i'm not sure, and a whole lot of other goodies. 500hp with 600+ NM worth of torque.
pete
Pete you also use Adrenaline don't you?
Do they have a datalogger?
And there's also Ovaboost... what are they like?
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
