oh n jenna do i have 2 call him directly?
Prob best if you speak to him personally, as if he knows that you know me, you will get a better deal. He always looks after me and my mates.
Jenna
sorry been really busy these days....candy job huh?They are great fun to do :D.Most of the motorcycles that we repair are candy colours......Candy's are what you call a monumeric colour Most have a silver metallic ground coat underneath...although what i like to do is lay a ground coat metallic colour thats close to the colour that i am chasing....eg if i want a yellow candy i make a yellow metallic pearl colour thats almost the same as the original colour inside the shop(you can never get the effect that candy colours give by trying to cheat with pearls/metallics...what happens is you can make the colour to look right under fluro light but under sun light its complety wrong or vise verser)then i will spray it out on a test card and wave coat by coat of the correct candy thats been broken down with clear and thinners....after each coat i check to see if i can get the correct flip in colours....when i have got it right i note the amounts of candy that has been applied to the card and transfer it to the job at hand......its a very lengthy process and one spec of dust in a candy job spells dissaster....the dust breaks the surface tension and candy pools to the low spot leaving a dark ring in the job.....A candy job really sorts out the men from the boys.....
yeah im gonna hold off for a while n def get a candy job done
thanx for the reply 2 troy i understand ur busy, u know 2 much!
wat i was gonna get is the silver metallic base with the gold metallic colour put on top... was using the House OF Kolor books to decide...
the colour almost goes to a bronze/brown colour when the sun isnt directly on it. looks mad
if ur up for one in 12 months time troy id be happy to swing by ur way as i might be livin in melb by then anyhow
hmmmm does it look anything like this?This is suzuki "burning copper bronze"
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
