Turbos:
Greddy T88H-38GK- relisting as buyer has yet to get in contact with me. Now has both 18cm and 22cm exhaust housings - $3200 firm + $500 for spare housing. Tran if you are reading this get in contact with me, I have been ringing your phone but no answer and not terribly impressed.
Garrett XR6 turbo - GT35/40R, internal wastegate 1.06 A/R rear. $1650.
HKS 2530 T25 flange - suitable for SR20 bolt on, has done ~1,000k's since new. $1500.
GTR stock turbo - one good one, another one with no exhaust wheel. $150 for both.
BOVs:
Greddy type S - have got one purple and one black. $150.
R34 GT-R stockers - comes with the alloy mount. $150.
Misc:
Moroso Accusump oil sump - new in box, ideal for wet sump arrangement and will prevent oil surge/low pressure issues. $250
HKS ETC + EDA - to suit R33, used for a few weeks. $800.
Thermo fans + shroud - EA falcon complete unit, brand new in box. Highest flowing thermos on the market. $220
JUN crank collar - $220
720cc injectors - used, set of 6 to suit GTR. $650
ECR33 driveshafts - snapped one recently? $80 each
Engine damper - bolts to strut top and top of engine, helps stop vibrations and breaking engine mounts. New in box. $250
Nismo white faced full dash - R33. 11K tacho, 320km/h speedo. Speedo was acting up when in car last, has 4,500 k's on the clock. $550.
Trust twin inlet intercooler - brand new in box, 600x290x80mm. $900.
HKS 100mm intercooler - single inlet/outlet, older style tube + fin. Some fins bent, no leaks. 600x290x100mm $800.
Air con panel relocator. For R33, mounts the A/C panel in the dash and has a replacement panel for gauges, boost controller etc. $200.
DBA rotors - new rear rotors for ECR33, one piece/slotted. $350
HKS low mount manifolds - stock replacement stainless steel manifolds with cross-over pipe. Used. $1100
C's quick shift - brand new in box. $370
More parts + pics to follow.
Blitz SBC-ID3 boost controller + Power Meter ID3 - used for a couple of weeks, didn't even install the Power Meter. Has the optional data input cable to read/log 3 additional inputs (oil pressure, oil temp, water temp, even knock). $700
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
