Auction Price Changes During Year
I remember reading somewhere a fair while ago that the demand for cars in the japanese auction houses changes throughout the year. eg - in month xxx people get their yearly bonuses so more demand for cars, in month xxx it's towards the end of financial year and companies want to get rid of their cars etc etc
Can anyone shed some light whether this is true and how demand does change throughout the year.
I'm looking on importing a late model R33 (1977-1998) and was wondering whether there is any benefit in me waiting a few months or not. R34 prices are too crazy at the moment so R33 it is.
-MearCat
ummm 1998 R33 GTS-T. 40th anniv. edition. black, manual, 65,000 on the clock
pretty much stock which is what i was after....
Of course the question most people will want to know is how much will it cost you (landed & complied) before registration
i wont say...but ball park....$18-$22k :)
Mmmm - a rather large ball park. :) But nevertheless, the upper part of the ball park is still pretty good for a 98 R33 - which can be harder to get hold of for a good price than 96 or 97
Edited by MearCat
Agreed BLO1 - the change in prices depending on time of year only really applies if you're buying a Toyota Crown or some other Yakuza staff car. Skylines are expensive all year round - in fact R33s are as expensive now as they were back when I was a buyer in 2000.
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
