Heres my Lozza
Some new Pics at bottom of Page
C33 Nissan Laurel
Inspection Front Bar
Wonder Side Skirts & Rear Bar
Flared and Rolled Guards
Deep Dish Wheels (16" Front - 17" Rear)
Xenon HID Head Lights - Very Bright Artic Blue
RB25det Engine Conversion
5 Speed Manual RB25det Gearbox
Trust TD06 Turbocharger
GTR Frount Mount Intercooler
HKS Air POD
Oil Catch Can
Aftermarket Dump Pipe
Full 3" Mandrel Bent Exhaust w/ Cannon
GTR Fuel Pump
Greddy Type R BOV
Remapped ECU
Turbo Timer
Pivot Air Flow Converter
Triple Layer Radiator
Twin Thermo Fans
Twin Plate Clutch
Nismo 2 Way LSD
Short Shifter
Kei Office Coilovers (Everything Adjustable)
Rear Adjustable Camber Links
Cusco Front and Rear Strut Bars
Cusco Front and Rear Swaybars
5 Stud Conversion All Round
GTR Brakes
Slotted Rotors
8 Point Roll Cage
Boost, Water Temp, Oil Temp & Oil Pressure Gauges
Nardi Personal Steering Wheel
R32 Seats
Raised Bonnet
Zip Ties in Front Bar
Power
Made 300rwhp @ 1.1 Bar
Pictures
Edited by j_insoll
https://www.sau.com.au/forums/topic/92608-nissan-laurel-rb25det/
konect - Yes the car is RWC and Registered, driven probably 2 or 3 Times a week.
jimbeam - I did not fit the TD06, a Japanese Guy did..........
Sky80 - Lier - I fitted an Oil Catch Can, Bride Seat, and put zip ties in the front bar. :lol:
But yes all the work was done in Japan
very nice... it must be much more relaxing to drift in a Laurel than a cramped up Silvia :D
I've got a TD06 waiting to go onto a RB25DET, so I'm very keen on finding out what engine mods and management you've got to support the beast.
very nice... it must be much more relaxing to drift in a Laurel than a cramped up Silvia :rolleyes:
To the Monkey that just so happens to be Funky........... :huh:
Mods are as per posted in the List at the top. Apparently the car has a 'Chipped' ECU, although we have taken a look and dont think it has been touched, though we could be wrong. The Injectors are also Standard RB25det Item. You most likely have the Trust TD06-20g. Mine I 'believe' is the Trust TD06-17c. As far as I know the 20g uses The Single Blade type wheel and the 17c uses the Double Blade type wheel (The 20g is the newer version obviously). I hope im making sense. Im currently running 1 Bar (14.7psi) and It makes full boost at around 4500rpm. Obviously this is a bit Laggy, although I have a feeling the Actuator/Wastegate may be a little bit loose, causing a bit of unwanted Lag. I have had this problem in the past.
With a RB25det, Upgraded Fuel Pump, 550cc Injectors, POD, Frount Mount, Exhaust and a Power FC, you should be able to put out approx. 340rwhp @ 1.3 bar. That would be my guess from what ive experienced with my car. Id guess it to spool up around 4000rpm. But hey I could be wrong!
