Hey,
I got a RB20DET in a silvia.
Just drove my car seems to be alot of steam or clear smoke not white coming from what seems to be around the rocker covers.....what could this be does not show on the temp dial thats its overheating.
But is has caused the car to stall twice so far and it wont kick over until you leave it for 5 mins.
I need any help i can get ASAP.
- Thanks Luke
Edited by RB20DET_Silvia
https://www.sau.com.au/forums/topic/92620-urgent-help-please/
I'd stop turning the engine over incase you're doing any more damage.
Does it smell like oil?
Do you have oil in your radiator? Do you have a full radiator?
I'd be looking for oil or a exhaust leak - depending on what it smells like.
Head gasket let go perhaps? did it occur after spirited driving?
The temp guage will read normal if there is no water in the system....it needs water to function correctly.
If you drove it till it stalled and did that a couple of times you will have warped the head. If may drive ok once the leak is fixed but get a leak down test done and find out how bad it really is. Another problem is that the turbo would have overheated severely also so there is a good chance that once you fix the problem, be it water pipe, welsh plug or head gasket, the turbo may have damage to the bearing which can cause them to fail soon afterwards.
Another problem that you will have to check is piston shrinkage. If it turns out to be a head gasket blown and you drove it until it stalled there is a good chance your piston can shrink in size once cool again. Make sure you get this checked out by whoever does the head work - BTW it will cost at least $600 to repair the head if it is warped.
have you found the exact point the fluid is coming out?
i had some trouble with my r33 dropping coolant but only after giving it heaps, never lost any thru normal driving. it was dripping down off the bottom of the block. traced the leak back to a tiny pin sized hole in a coolant line close to the block, guess that the leak was forced due to higher temps/extra pressure in the lines.
have since covered and clamped the hole (no more leaks even after hard driving), and am replacing the lines this weekend.
not sure if this is relative, but may be worth checking.
maybe a cracked block?
Look, engines run on smoke.  Once all the smoke gets out they are dead.
aaaahhh, i see you are wise in da ways of da smoke. applies equally to electrical systems particualry those installed in pommy cars and affiliated with lucas aka the prince of darkness.
You will be looking at a minimum of around $1000 to do a head gasket on one of these if you go through a workshop.
$1600-$1800 if the head is bent (which it more than likely is)
$4000 if the pistons have shrunk.
Good luck, let me know if you have any issues. I have dealt with many of these.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
