Drift Wa Dyno Day
SR32
 Share
DRIFT WA DYNO DAY
BBQ / BEER / COOL DRINK
AT:
HYPERDRIVE
Unit 1/28 Vale Street Malaga
DATE:
Saturday 19th November 2005
10:00 AM Start
COST:
$40 Per Car
Includes 2 runs back to back
Print out of shootout accredited and signed results
IF YOU WOULD LIKE TO ENTER:
Email [email protected]
Please include the following details...
Name:
DriftWA Forum Name: (if you have one)
Contact Number and Email:
Vehicle Make/Model/Engine:
Vehicle Rego:
Please Read:
35 spots available.
All care will be taken, but you will be required to sign a disclamer.
Open to everyone who doesn't have a 4wd, GTR's are fine as they can be switched to rwd.
Drunkeness will not be tolerated.
Drink responsibly and the responsibility is yours and yours alone.
If anyone wants to donate or can organise prizes, help appreicated.
BBQ/Beer/Cool drink will be for sale.
Drift WA stickers will be for sale.
D R I F T W A . C O M
They sure can baz.
Can't wait to get my ebc set properly then see her potential! :O
Also our lovely (erm, maybe not lovely, let's say nice) friends at hyperdrive have donated a prize!
WIN a free power run to be used at a later time.
Normal price on these shootout accredited runs is $70.
Thanks to Hyperdrive.
Money & Disclamers can be paid on the day, or beforehand (it's up to you).
No other forms to fill out, but you will need to send an email with all your details to register.
Maybe we can organise some legal street drift out the front of hyperdrive hey Ken?... but they did it in NZ :(
Drift WA would love to be able to hold drift events, but long story short...it's far off.
Dyno day has been postponed due to lack of Ultimate 98 ( thanks BP you $%$#&**s !! ).
Not recommended to dyno on anything else so will advise later when BP decides they will make some more.
* where is Shell Optimax when you need it...* :(
Cheers
Ken
  • 3 weeks later...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
