Reved to 7500rpm in tune.
To fit this turbo you need to have adapter, new oil+water lines, dump pipe. A bit of fiddling otherwise happy.
Yep the GT28RS is a 'disco potato'. I would assume its not a straight bolt up. Did he use an adapter plate? Cos they are a T25 flange normally...
good result
very similar to mine if you compare... mine is a little more responsive now, going in for 20psi tune this sat. i think u should do that as well so we can compare :)
http://www.antilag.com/not300.JPG
Edited by Cerbera
  • 3 weeks later...
Roy, sorry its abit late but only just saw ya question!
in answer, its been off the road for some major modifications last few months but will be back on the road with the k27 in a week. will update you if you like.
