The RB25DET Neo has infinitely variable VVT, unlike the RBDET non Neo which is a simple on or off. So the ECU's (inc PFC) are quite different, and the ECU pinouts (plugs) are also very different.
The easiest way (that I have found) is to use all of the parts from the same model that means sensors, harness and ECU. So you could use all R34GTT parts, just check for prices, they aren't cheap. The cheaper alternative wouldbe to use all of your current R32GTST parts. This would mean no VVT, but it would be the easiest/cheapest.
:D cheers :)
When we were doing my Neo conversion we noticed that the wiring looms between the R33 and R34 motors are really quite different.
I'd be biting the bullet and using the loom as well. If you're going to go as far as buying a new motor with the purpose of doing an engine conversion then to give yourself as little hassle as possible you really should be using the loom for that motor as well.
I put one into an R33, using an R33 loom and ecu.
The changes I needed to make were as follows:
1. CAS wiring is backwards - a simple cut and solder will work here;
2. Use an R33 throttle body to save on changing wiring there;
3. Change the plugs on the VVT and idle control valves to suit.
It'll work fine this way and you could use a R33 loom and PFC, you just wouldn't have the "infinitely" variable VVT, but the on/off system that the R33 has.
Definitely a worthwhile conversion over using an R33 RB25DET as the power delivery seems so much better - well to me anyway.
hi
sorry for hijacking the thread but im also about to get a rb25det neo for my r31... i get it either tomorrow or the next day... whats the problem with using the r34 throttle body... ive heard its electric or sumthing but wouldnt you just hook the accelerator cable up to some sort of sender box or is there more to it
the one im getting has gearbox, motor, new turbo, gearbox yoke, computer and wiring loom ect ect just not the actual halfcut
will i have this problem 2 or wat other problems will i discover
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
