Where is it loose?
Towards the windscreen or towards the bumper?
if it is towards the bumper then you can get the rubber stops on the side replaced. They are about 10-15cm from the edge. You can adjust them up and down by turning them. If they are missing, just go to Nissan to get some more - or any other car dealership, they are usually much the same.
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1671271
Where is it loose?
It toward the windscreen. Both the right hand and left hand side are loose...
We can I get a replacement for that... Or is there any stopper I can put to prevent it from rattling?
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1673152
Dude if you have a look it most likely is only the bolts on the hinges that are loose from the way you are describing it.
Other causes that spring to mind are the ''rubber stops'' that screw into either side of the ''radiator support bar''.These give the front of the bonnet somthing to sit against frimly so the bonnet doesnt fly freely in the wind at high speeds.Id say if the bonnet can be moved at the front of the car chances are you will have to adjust the height of them to a higher level.
Other than that it might be the catch that is giving you the problems.If so tighten all the bolts,top to botom,as needed.I think that there is one on the botom and 4 up top.
Hope that helps.
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1674029
If it's towards the windscreen where you are saying, then you need to check to make sure the bolts holding the bonnet on are tight. If they are then the hinge itself needs to be replaced. Just check the bolts first, they could be loose.
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1674897
Ya the bolts is loose however i dun see a way to tighten it at all... Cos there isnt any nut that I can tighten....
What should I do???
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1675125
Then they aren't the bolts, they are the rivvets that hold the hinge together. You will need to replace the hinges. What state do you live in? and can you post a pic of the hinge in question with a paint shop arrow to what part is loose. I can try to track down some new hinges for you if you like.
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1675152
Thanks a lot
I am staying in brisbane
Will take the photo and post it in question
Thanks in advance
https://www.sau.com.au/forums/topic/92643-bonnet-loose/#findComment-1676260
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
