i want to convert my air con to R134A as it was imported as R12. Does anyone know where i can get a conversion kit with new reciever dryer and pipe fittings to do the conversion, i'm sure someone has had to do this before, i don't want to know where i can get it done as i'll do it myself just where to buy the parts. thanks in advance for any help
Edited by marcus32
https://www.sau.com.au/forums/topic/92645-r12-to-r134a-conversion/
You are not allowed to do it yourself. You have to be a certified A/C repairer to do it. The old gas has to be stored in a container and disposed of properly because it is ozone depleting. The R134A gas is toxic to humans. Cost is $200 if you live in brisbane, PM me for details if you wish.
well to give you the facts i work in a dealership thus all parts are genuine so i didn't know that jayair supply them thus why i asked. next time just answer the question without being a smartarse.
Well I'm sorry that you thought I was being a smart arse but that was not how I intended it to read. There's the information - would you like part numbers also?
I have a full list of them at work (won't be til Monday now though)
No worries, I will find out on Monday. I just spoke to my boss then and he hasn't got anything listed as specific for the R32 GTST but he said that we will definately be able to match it up so I'll take mine off on Monday and get the number for the correct parts and prices. Shouldn't be any more than around $40 for everything.
OK, here are some pics of my RECEIVER/DRYER which is to suit an R32 GTST
If these match yours, then the part number is RD5010
The dimensions are 200mm HIGH x 60mm DIAMETER. M20 Thread on inlet and M16 thread on outlet. It has two male switch points perpendicular to the in/out. Only one should have the sensor in it.
so what exactly has to be changed? my whole system is out at the moment, so i might as well buy the parts and change everything over, then get it refilled proffesionally.
steve
The only things that require changing are the RECEIVER/DRYER (pictured) and the fittings to the High and Low side of the system - Red and blue caps.
Red is high, Blue is low.
And dont treat R134A with contempt either. Whilst it may not harm the ozone, it still contributes to global warming. It too will be phased out of use and replaced with Carbon Dioxide
R134a still harms the ozone layer... just about 1000 times less than R12
  • 8 years later...
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
