i want to convert my air con to R134A as it was imported as R12. Does anyone know where i can get a conversion kit with new reciever dryer and pipe fittings to do the conversion, i'm sure someone has had to do this before, i don't want to know where i can get it done as i'll do it myself just where to buy the parts. thanks in advance for any help
Edited by marcus32
https://www.sau.com.au/forums/topic/92645-r12-to-r134a-conversion/
You are not allowed to do it yourself. You have to be a certified A/C repairer to do it. The old gas has to be stored in a container and disposed of properly because it is ozone depleting. The R134A gas is toxic to humans. Cost is $200 if you live in brisbane, PM me for details if you wish.
well to give you the facts i work in a dealership thus all parts are genuine so i didn't know that jayair supply them thus why i asked. next time just answer the question without being a smartarse.
Well I'm sorry that you thought I was being a smart arse but that was not how I intended it to read. There's the information - would you like part numbers also?
I have a full list of them at work (won't be til Monday now though)
No worries, I will find out on Monday. I just spoke to my boss then and he hasn't got anything listed as specific for the R32 GTST but he said that we will definately be able to match it up so I'll take mine off on Monday and get the number for the correct parts and prices. Shouldn't be any more than around $40 for everything.
OK, here are some pics of my RECEIVER/DRYER which is to suit an R32 GTST
If these match yours, then the part number is RD5010
The dimensions are 200mm HIGH x 60mm DIAMETER. M20 Thread on inlet and M16 thread on outlet. It has two male switch points perpendicular to the in/out. Only one should have the sensor in it.
so what exactly has to be changed? my whole system is out at the moment, so i might as well buy the parts and change everything over, then get it refilled proffesionally.
steve
The only things that require changing are the RECEIVER/DRYER (pictured) and the fittings to the High and Low side of the system - Red and blue caps.
Red is high, Blue is low.
And dont treat R134A with contempt either. Whilst it may not harm the ozone, it still contributes to global warming. It too will be phased out of use and replaced with Carbon Dioxide
R134a still harms the ozone layer... just about 1000 times less than R12
  • 8 years later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
