  • Replies 43
Posted Images
From what I understand the situation was that they axed the skyline due to expense and the car dealers demanded a skyline badged car so they wacked one on these imposters and it stuck. The new GTR looks cool enough but can't wait for engine details, I'm sure it will be a world killer.
Is this the model that is known as a V35 infinity in the states?
Therefore would be badged as a Skyline?
or am I barking up the wrong tree?
modr33s2, you know the R34 and the V35's were in production at the same time right? 2001 was the transition year, and Nissan announced that it was to be the next skyline a while before that.
The skylines always traditionally been a passenger car with the occasional generation getting the GTR model. The move to a V35 sedan in japan was pretty well recieved, even by some hardcore enthusiasts, as it was the Skyline getting back to its grass roots. But, you can't please everyone.
I'm afraid I'm not impressed with the V35 it's just another Euro trash design that looks like a 300zx on Steroids. There's nothing inovative here just less individuality, it could be a toyota V35 and you'd never have a clue. <_< BORRRRRING.
Renault has taken the design soul out of nissan and focesd their effort on the SUV crap that is the latest and greatest.
M2C
One of the guys at work informed me that next week hopefully we will have some new version of the Skyline coming to us. Apparently it is waiting at the docks. If I heard right it will be the 2005-2006 model. If it comes through I will try to get some photos.
  • 4 weeks later...
its bcoz the blue one is a coupe, and the other is the four door version.
I have warmed to the V35 350gt they look awesome with a bodykit but I still cant come to terms with the 4 door. I guess as others have stated its the euro and american influences that have changed the styling of the car. But hey if I was handed the keys to one I wouldnt say no!
Agreed. Also the advertisment for the blue one states further down that it is a 2003 model, so that would also account for the difference in price.
Looks good with body kit, lowered suspension and rims added.
Cheers
Edited by SMR33
Okay, I just thought I would clear this up....the four door one is not a 350GT. It is advertised as such but is only the standard V35 3.0L.
That is why it is so cheap.
The blue one is a true 350GT. We have one at work for sale for $50,000.
And a 260RS Stagea for $40,000....both complied.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
