As it says guys if we want to be dickheads lets do it here.
http://www.wsid.com.au/MajorEvent.asp?Even...age=Information
Please post intrest as Leech thinks hes going to whip my arss (more then likely will)
No slicks Lee. I still dont have a camber kit either.
This has been brought up due to ppl winging about friday nights events. SO lets get a group and go race.
https://www.sau.com.au/forums/topic/92684-wsid/
lol i never said i would win i actually said i would loose but i want to see by how much :( just out of interest whats the go in terms of how early you have to be their for a checkin type thing eg could i drive up after work eg 4pm or something have a couple of runs then drive home ???
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1671979
i'm not going to bother, my car isn't a sports car and i don't drive it like one :D would be good to watch though, but wsid is a bit far on a friday night.
i think its only on wednesdays anyway and as if not take the stag up awd + rb25det would be great not sure how heavy those beasts are though
well maybe we look to get a bunch of us up early jan ???
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672512
i'm not going to bother, my car isn't a sports car and i don't drive it like one :) would be good to watch though, but wsid is a bit far on a friday night.
Sports car?
You don't need a sports car for WSID... any car can go flat stick down a straight line :D
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672648
it's not the awd and rb25det, it's the auto + 1800kg with fuel/driver that makes it slow. i'm going to keep this wagon in good condition, then when i get the Autech, i'll take it on a track (RB26DETT + 5spd awd wagon)
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672793
SOFTTTTTTTTTTTTTTTTTTTTTTTT it seemed to keep up fine on friday
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672938
Autech? MMMmmmm...260RS=yummo! When's this changeover gonna happen,Termi'?
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1675403
this sounds awesome.......
however, i do think if it is to be organised, it should be done for some time in the new year. its a wednesday night, some ppl need to get the time off work and this gives us plenty of time to organise one.......
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1676261
ok so the general consences is to have this after the new year, ok sounds good to me i was hopping sooner but hey there is already plenty of things coming up soon, like formals and Cars in the park on THE 20th OF NOVEMBER
Edited by race_snooze
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1676689
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
