I was lead to beleive this was a VG30 turbo, I had plans to use the turbine housing to ad to my hi-flow of my stock RB25 turbo.
I didn't know exactly what the VG30 was supposed to look like but if someones selling an apple you'd think it would actually be an apple, right?
I thought the VG30 was supposed to have a larger turbine housing so I sent photos to GCG in Sydney for a discription on what I had just bought.
They came back saying it's an SR20/CA18 Garrett T25 turbo and asked (quote) "Who the hell told you thats a VG30?"
So my question is - Is it a VG30 or a Garrett T25?
If GCG (with their experience in turbochargers) are wrong about this one (as one person thinks) and it is in fact a VG30 then I will personally give the turbo back to the seller (he can keep my money as the turbo is useless to me) and he will have a true honest apology!
Thanks..
https://www.sau.com.au/forums/topic/92686-what-turbo-is-this/
hey PRESA .. im going to my engine builders tomorrow to pick my RB25 head .. i'll check the SR20 thats sitting at the workshop...
also have some stock CA18 ones sitting at a mates that i can check too..
would be easier if you could give us the numbers on the plate between the housings would make it easier!!
Ok Sweet.. the turbo is at work so I'll post up the numbers tomorrow.
It's pretty filthy of oil and stuff but when I had to give it a whipe back I noticed the GARRETT logo on it and then I could just barely see A/R .45 or .48. Thats when I thought hang on - I'll ask GCG before I send this up to them asking to hi-flow this for my RB25.
I was told by discopotato awhile back that RB20/RB25/VG30 are all nissan turbos manufactured by Hitachi and not to confuse them with anything to Garrett. The only vague similarity are the T3 flanges - which this turb doesn't have.
** I can post up photos of the flange if necessary.
if i look for a hiflow / aftermarket option im gonna be speaking to racespec see what they can do as far as a garret equiv of the hks gt-rs im pretty sure they can do a gt-rs spec for cheaper or even a gt-rs front wheel and compressor and vg30 rear supplied as well
if i do consider it, which will be never
if your still gonna post the details try and make it before midday.. otherwise i might miss it..
but its almost ruled out the possiblility of it being the SRorCA turbo .. but i can check still
OK I had a look..
It has a Garrett logo on the top.
Underneath it says -
SK 16395
14411-40P16
466083-1
here you go:
I quoted the number 14411-40P16
http://300zx.lv/catalog/?pn=1441140P16&pt=...feb06b2de0c62e4
Don't believe me? Here's another
http://www.turboservice.se/Nissan.pdf
I guess your "boys" at GCG need to reconsider there occupation and maybe do the logical thing and go off the serial numbers :)
Apology?
:O
Edited by nuR.spec
it was never stated as being a VG30DET turbo, it clearly stated that it was off a VG30DETT..
Actually the OP has it as 'VG30' and it is clear that some don't understand that there is quite a difference between a VG30DET turbo and a VG30DETT turbo. It is also clear from the first post that he was after a VG30DET turbo, but has actually bought a VG30DETT turbo.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
