Your topic for the ad was VG30, that can easily be misinterpreted to beleive it was VG30DET or VG30DETT.
All I knew is that I wanted the VG30 turbine housing which was larger than my RB25 for a hi-flow and I told you that but you didn't have a problem taking my money and then basically tough luck you can't have it back now.
I didn't know what to look for when buying it other than the larger turbine housing and with the dump pipe and heat shield on I couldn't see that.
Now it's just gotten to the point that you knew what my plans were for it and that it would be useless but you still took my money and refuse to give it back.
Is that how someone should trade on these forums?
If GCG (with their experience in turbochargers) are wrong about this one (as one person thinks) and it is in fact a VG30 then I will personally give the turbo back to the seller (he can keep my money as the turbo is useless to me) and he will have a true honest apology!
Im still waiting B)
Im sorry to say but your clueless as f***.. You've seen for yourself the handful of people on here who "think" they know it all.. leave modifications as such to people who know what there on about (someone like GCG :lol:)..
end rant!
Edited by nuR.spec
end rant!
look mate, you've knowingly farked this guy over and yes he may have been naive in thinkin that all people around here are honest and helpful, but get over yourself.
you sold him a useless turbo, fair enough, thats between the two of you to sort out.
but getting on here and rubbing it in and giving crap to GCG is not gonna impress anyone.
random preson with 38post V's a SAU-Vic member,
gezz i dont even need to read the thread to know who is in the right and who is in the wrong.
Presa, i think u should pm blitz or prank and informed them of what has happen so they can ban this f**khead or watever they find fit
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
