once i saw my mechanic trying to start a car and it was also struggling, he poured some hot water on the terminals and up it went. but i'm assuming that just to melt any crap effecting the connection plus it'll be pretty messy if you pour anything in the boot of a skyline.
https://www.sau.com.au/forums/topic/9270-battery-prob/#findComment-138974
if your battery dropped a cell, it would be totally ****ed by now. if your altenator was ****ed, the car would be cutting out while driving, and it wouldbe trashed. the only way the deck would be draining power is if it is wired up to direct positive power instead of ignition power. i dont know what other electrical after market accessories youve fitted, but all i can suggest to try is checking them.
https://www.sau.com.au/forums/topic/9270-battery-prob/#findComment-139417
A healthy 12V car battery will float @ ~12.2-12.4V give or take.
A healthy alternator will put out ~13.8-14.4 give or take (mine is 14.2V)
*Important note* - this will not change with rev's. If the voltage increases as the rev go up (14V @ 800rpm 16V @ 4000rpm) the regulator is not working. This will cook your battery.
I'd get a multimeter & recheck your battery & alternator to see they are within the above V ranges.
https://www.sau.com.au/forums/topic/9270-battery-prob/#findComment-139789
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
