Hi guys..
been absent for a while on here.. moved and have no computer.. ;)
ANYWAY....
I need some new tyres for the rear..
Could anyone steer me in the right direction for new tyres in the south east.. where they are not over priced! apart from TTF in Dnong.. had bad experience with them in the past. :D
Thanx heaps!!!!!!!
https://www.sau.com.au/forums/topic/92717-good-deal-on-tyres-in-seast/
I bought Hankook ventus k104s in 235/45/17 for $175 from Joes Tyres in Moorabin.
The best way to look for tyres is decide what brand you want, then look at their website for their preffered suppliers, as they have them for cheaper than anyone else.
sorry 255x17 i meant
nah just an awesome compound tyre
provide stacks of traction and a very nice all rounder
getting them again soon. last about 15 months (28,000 k's) on good rwkw gtst
Hey.. thanx for your help guys..
I aint paying $410 for 1 tyre!!!!! lol
What are some good brands of tyres to get??? cos i wouldnt have a clue when it comes to tyres.. i just know that they are round and black..lol
Hi guys..
been absent for a while on here.. moved and have no computer.. :)
ANYWAY....
Could anyone steer me in the right direction for new tyres in the south east.. where they are not over priced! apart from TTF in Dnong.. had bad experience with them in the past.  :)
Thanx heaps!!!!!!!
The hankooks are cheap for a reason. The reason is they are shit. Get something better.
I noticed ur car also had as nice dent in the rear end last time I saw it in hampton Park??
Wasnt that the manufacturer Mavric had problems with grip on also? <_<
Donnellans Box Hill are my choice.
Either that or City and Rural in Cheltenham.
Both have a great selection and reasonably priced.
I'm running the Falkan Azenis ST115 275/35/18 on the R atm. Good value for money rubber.
Was running DJ01s but they wore too quickly on the street.
Hey Denham.. long time.. ;)
Yeah.. i didnt put my h/brake on properly one day and it rolled down my driveway into the pole on the other side of the road.. :D its fixed now though :(
Thanx for all your help guys!!!!!!!!
ill be going around to a few places tomorrow..
hopefully ill be able to find some.. i need them pretty quickly too.. really bald on one side.. might aswell get a Wheel a/ment and balance while im at it i think
Thanx again guys!!!
TTFN
Fingers crossed you'll get to take those new tyres for a spin to the other side of the city with me to pick something up!! ;):D
Edited by [ STAGEN ]
Hey Denham.. long time.. :(
Yeah.. i didnt put my h/brake on properly one day and it rolled down my driveway into the pole on the other side of the road..  :D  its fixed now though  :D
Thanx again guys!!!
TTFN
My gfriend always sees ur car parked at a house in hampton park near the church there.
Have u moved there?
I'm with Dave on this one.
They were considerably the cheapest around when I was shopping.
Although Clayton Beaurepaires ended up matching their price. A long story, but Clayton was more convenient for me.
Yep I've gotta agree with INASNT on the Hankooks- I just bought a GTR last Friday & it's got these on all fours & I've gotta say I'm NOT inpressed, i nfact it's embarassing how little grip they really have when pushed
It's part of owning these things, put good rubber on 'em 'cos you'll either bend 'em at best or put yourself in a box..........
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
