I was taking to the tyre dude today as I was getting my T1R's fitted.
He mentioned that for performance cars its best to have nitrogen in the tyres instead of air.
So.. What are the pros and cons? He said @ $9 a fill for one tyre.
What happens if you break down or if you have a punture? What happens.
Does anyone use this stuff for road use? or mainly for track?
Ive search the word nitrogen and nothing comes up in relation to tyres (only one person has said they will do it.).
Any info would be good.
https://www.sau.com.au/forums/topic/92790-nitrogen-filled-tyres/
pros.
Nitrogen does not contain moisture and is much more tolerant of change in temp. eg less expansion or retraction therefore keeps a more stable pressure in hotter or colder conditions. Hence they use it in aircraft tyres.
cons.
its heaver than air, its expensive.
What happens if you break down or if u have a puncture?
Common sense tells me to either call for help or change the tyre.
At 9 bucks a tyre i would not waist your money. if u go to the track simply drop the pressure in your tyres. when they warm up they will increase pressure.
Unless you're going to use it for track work, or you've got your own nitrogen pump, I don't think its worth it.
The pros given by Damo are correct. You don't get the changes in tyre pressure that you do with air as the tyre heats up, which makes them more consistent and less likely to overheat.
But its hard to find a pump, and so if you get a slow leak or want to tune your tyre pressures you'll be out of luck.
When I get a second set of rims I'll probably use nitrogen in my track tyres, and use regular air in the street tyres.
As an aside, which tyre dude has been the only one to say they'll do it?
cons.
its heaver than air
Have you got any references for that?
Air is just under 80% nitrogen, and 20% ozygen. You've got 1% Argon, and everything else is just a rounding error.
Oxygen and argon are heavier than nitrogen, so assuming you're scientifically rigorous enough to be comparing the weight at the same temperature and pressure there's no way pure nitrogen could weigh more than air.
To the best of my knowledge you don't have to run higher pressures with pure nitrogen than air but I could be wrong. If so, then I guess nitrogen-filled tyres will weigh more...but you'd have to be a bloody good driver to notice.
Yep your right, got it mixed up. Sorry, had 1 too many beers last night.
The 100% nitrogen filled tyres don't increase pressures as much as ambient air does when the tyres get hot. So they are more stable in their tyre pressures. My understanding is this is mostly due to the humidity (H2O) pressent in ambient air. Which, when it gets hot, breaks down into hydrogen and oxygen and increases the pressure accordingly.
So when they say "humidity is 40%", what does that mean to the 79.5/19.5/1 mixture? Does it become 47.5/11.5/1/40?
If so, that's why the pressure goes up so much if you have 40% of the contents of the tyre splittting into hydrogen and oxygen.
:rolleyes: cheers :)
most of the benefits you get out of nitrogen filled tyres, can be achieved by using dry compressed air.
Moisture content in the gas you use plays a much larger part than the gas itself.
Aircraft tyres tend to use them because it's an inert gas, and reduces the risk of fires/tyre explosions.
I'm not sure what the activation energy of water is, but are you sure that there's enough heat in the tyres to do that kind of thing? The last time I hit the track my tyres only reached around 50 degrees on the surface of the rubber.
And what do you do afterwards? Anyone who's studied the history of airships knows how safe hydrogen and oxygen are when mixed together and heat is applied. Also, since gases occupy more volume per molar count than liquids, that would leave your tyres with a higher "at rest" air pressure afterwards. Of course, depending on the humidity in the tyre in the first place it may or may not be detectable with a commercially available gauge.
If that was enough to break down hydrogen and oxygen, boiling water in a semi-sealed environment (like a kettle) where the boiling water vapour is kept at 100 degrees+ before being vented to the atmosphere would probably get you killed if you smoked anywhere near it.
Once again this is pure speculation on my part (I wouldn't even call it a hypothesis since I'm not that up on chemistry), but it just seems like if there was enough heat in tyres to break water down to its base elements there would be a lot more cases of tyre blowouts during enduro races.
Trust me, theres no way you'd be splittin H2O in your tires. :D)) (Drawing some vague knowledge from uni chem) H2O just wont spontaneously split in 2 on its own without some sort of chemical or metallic catalyst or current.
To put this into perspective, to get N2O (Nawwss) to split into nitrogen and oxygen spontaneously, it needs to be exposed in combustion chamber (1000C) for it to give you the O2 to give you the 'go'. Unfortunately even so, this aint the same with H2O. Tyres at 1000C anyone? Haha
Boiling water just means the water has changed from a liquid to a gaseous state. It doesnt mean the water is splitting up, or it wouldnt be water anymore would it? (Ie water vapour)
Edited by Busky2k
The increased temperature just means the molecules will move about faster and with more energy, which equates to a rise in pressure. You are not actually spliting the H20. PV = MrT is the equation :D P = Pressure, V = Volume, M = Molecules, T = Temp. and r is a constant.
From my understanding having N2 filled tyres only makes pressure more predictable and less changing under temperature changes. I have seen you can get it for road tyres now but can't see the value. Particularly at $9 a corner...
BTW for those saying its good for race cars not road cars, I think its the opposite.
Its great for your average car driver, set it once when you put the tyres on, and throughout the tyre's life it won't change by more than 1 or 2 psi (assuming no leaks). Perfect for set and forget and you always get optimal tyre performance
On a race track on the other hand, you can expect to need to change the tyre pressures most sessions, and that means you would have to take nitrogen with you. For track use pressures on the same car are affected by the direction of the track (clockwise or anti), track temp that day, and even fine tuning of the car's balance.
But does it work? Have your pressures changed?
Could you please do a measure now and post what pressure you put in, what it is now and the time frame? I am currious to see if this actually works or not.
Real world experiences;
I know that on a humid race day we have to bleed off more pressure in the tyres (as they heatup) than on a dry day. Note that is using a compressor with no water filter to pump up the tyres. I always put that down to more water vapour in the air. Not water itself.
I know that using air from a cylinder we still have to bleed off pressure in the tyres, just not as much as what we do out of the compressor. I always put that down to less (maybe even zero) water vapour in the cylinder.
I know that nitrogen filled tyres take even less bleeding off, I put that down to the lower expansion properties (due to heat) of the nitrogen versus air. ie oxygen (+ other gases) expands more when it is heated from ~20 degrees to ~70 degress. I don't know whether that is true or not, all I know is there is less expension from 100% nitrogen
:D cheers :(
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
