i am also currently looking at one of the FPV typhoon intercoolers to fit to my series 2 and would be interested to hear if it was successful?
of if anyone else in here knows wht they are rated too for flow etc.?
  • Replies 254
Posted Images
i noticed all you guys are talking about a cooler with piping that enters and returns thru the same side so no holes have to be cut in the chassis.i wanted to do the same thing on my 33 so i went and got some pipe bent up at an xhaust shop and fitted it in 4hrs. only did it cos i was in a hurry to get it on, have now changed my mind and wana get it repiped properly cos the lowness of the bottom pipe is pissing me off hardcore.
i have a new PWR core here but thinking of going an r34gtt cooler and duct, summer has made my car so unresponsive, will a GTT cooler help much for responsiveness over summer on a stock car, or just go FMIC straight away(dont really wanna fork out for piping), also the FMIC takes air away from the radiator, hence the appeal of the GTT cooler.
-Ryan
heya all
i just won a typhoon intercooler from ebay for $80 so cant wait to get it and clean it out etc. then the hunt will be on for some pipework and joiners so ican fit it up.
then i spose it will be a trip back to the dyno to see if it makes any difference in the tune and boost levels etc.
-Ryan
Anyone?
no it didn't need cutting.
confirming it is this kit?
Cooling-Pro Intercooler Piping Kit - Skyline R34 GTT Price: $299
Includes Piping - Hoses & Fittings
Suit 600 x 300 x 76 Sized Intercoolers
would that mean a trust r34gtt kit wouldnt require the cutting of the battery tray where an r33 gtst kit does? interesting
thats the one, however we bought the whole intercooler kit, but i'm sure the piping is the same.
i used a r34 gtt kit and needed to cut under battery,trim the bar where the piping joined cooler,also my fan had to lose a little bin of it fin,
you have to cut under the battery for all the intercooler kits that dont use the stock piping, but you dont actually cut the tray (unless thats what ryan is refering to as the tray...?)
i wouldnt recommend cutting the fan though, becuase a) you shouldnt need to, kylies doesnt touch the fan, there is a bracket that attaches to the front engine removal bracket, and b) it can unbalance it, and cause it to shit itself. i replaced the clutched fan on my 33 with a pair of 12" thermo's.
  • 6 months later...
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
