Hey guys,
I just fitted brand new NGK Iridiums to my 1993 RB25DET. The car has only a cat back exhaust, BOV and a pod filter (stock ecu/boost).
I had the new plugs fitted I thought it missed from dodgy plugs and when the old ones were pulled out they looked pretty average so I had the NGKs fitted.
After doing this the car still misses when it comes on boost or under full load. The guy who fitted the plugs also adjusted my idle rpm as he thought it idled too high, but this was only because the car was freezing cold. I presume this is done by adjusting the timing?
Could this have played a part in the car still missing with fresh plugs?
Cheers!
Matt
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/92835-missing-at-hi-rpm/
Hey guys,
Cheers!
Matt
What plug gap did you use? The standard gap is 1.1 mm but this can be too large. I had the same problem when my plugs were changed. had to re-gap to 0.8 mm and then was OK.
Also check coil packs.
See http://www.skylinesaustralia.com/forums/in...lug+gap+rb25det
He may have missed that the throttle was not closed when he checked the timing. To set the static timing the ECU must register that the throttle is closed and that the engine is up to temp ie above 80deg. Once these two conditions are set that timing should be 15 deg. Now if he adjusted the timing with the TPS not registering closed throttle the timing numbers shown on the timing gun would be around 18 - 20 deg in which case he may have retarded the timing 3deg which is more than enough to cause a miss.
If he thought it was idleing to high he should have adjust the IAC bypass valve not the timing. Alot of people dont realise that retarded ignition timing can cause a miss fire event.
Your mechanic sounds like a dick!
Take it to someone that knows RB engines.
If your car is missing with 0.8mm gap, you will more then likely have a dud coil. (Hairline crack from heat, allowing spark energy to escape)
For standard boost, you shouldn't even need 0.8mm gap. But it will prove if its the spark or not.
If you are running more then standard boost, it could even be the infamous Nissan "Rich and Retard" happening. This is where the ecu uses parts of the maps that are very very conservative with timing and very heavy with fuel. This might be what your feeling as well.
Good Luck!
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
