Hey guys,
I just fitted brand new NGK Iridiums to my 1993 RB25DET. The car has only a cat back exhaust, BOV and a pod filter (stock ecu/boost).
I had the new plugs fitted I thought it missed from dodgy plugs and when the old ones were pulled out they looked pretty average so I had the NGKs fitted.
After doing this the car still misses when it comes on boost or under full load. The guy who fitted the plugs also adjusted my idle rpm as he thought it idled too high, but this was only because the car was freezing cold. I presume this is done by adjusting the timing?
Could this have played a part in the car still missing with fresh plugs?
Cheers!
Matt
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/92835-missing-at-hi-rpm/
Hey guys,
Cheers!
Matt
What plug gap did you use? The standard gap is 1.1 mm but this can be too large. I had the same problem when my plugs were changed. had to re-gap to 0.8 mm and then was OK.
Also check coil packs.
See http://www.skylinesaustralia.com/forums/in...lug+gap+rb25det
He may have missed that the throttle was not closed when he checked the timing. To set the static timing the ECU must register that the throttle is closed and that the engine is up to temp ie above 80deg. Once these two conditions are set that timing should be 15 deg. Now if he adjusted the timing with the TPS not registering closed throttle the timing numbers shown on the timing gun would be around 18 - 20 deg in which case he may have retarded the timing 3deg which is more than enough to cause a miss.
If he thought it was idleing to high he should have adjust the IAC bypass valve not the timing. Alot of people dont realise that retarded ignition timing can cause a miss fire event.
Your mechanic sounds like a dick!
Take it to someone that knows RB engines.
If your car is missing with 0.8mm gap, you will more then likely have a dud coil. (Hairline crack from heat, allowing spark energy to escape)
For standard boost, you shouldn't even need 0.8mm gap. But it will prove if its the spark or not.
If you are running more then standard boost, it could even be the infamous Nissan "Rich and Retard" happening. This is where the ecu uses parts of the maps that are very very conservative with timing and very heavy with fuel. This might be what your feeling as well.
Good Luck!
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
