Hi.
Just bought a Series 2 R33. The engine is stock, with just an aftermarket exhaust and a K&N panel filter in the box.
While I'm idling at the lights, every say... 10-15 seconds or so... I'll feel something like someone hitting the back of the car with a basball bat. I reckon it's in the exhaust system cos I hear what feels like the engine nearly misfiring... it's weird. But I don't think its an actual misfire cos that would be every cycle right? and this is only every 10-15 seconds.
First time I noticed it, I had the A/C on. I'm used to a civic where if i had the A/C on u REALLY new about it.. car lost all guts and u could feel the A/C cut in and out while idling.. I thought this might be the same. I think it *may* have lessened the severity but that may just be wishful thinking. I don't think it should be doing it at all, eh...
Car is under warranty and I can get it fixed for free if needed, but I'm just wondering if this really is something "wrong" and wanna know what it is before bothering to go back for something that may not need repairing (I'd be surprised if it doesn't though.. it's a bit freaky when ur sitting there and suddenly it feels like someone gives u a right royal kick in the pants lol). Even my gf looked at me the first time and went "wtf was that?!" and she has NFI about cars.
Didn't notice during the test drive cos was having too much fun.. and the NRMA report didn't turn up anything untoward.
Anyway, interested in suggestions. Thanks in advance.
https://www.sau.com.au/forums/topic/92885-weird-thud-while-idling-cause/
I've been running 98 fuel only. Well I said it was maybe worse with the AC on compared to off in my post, so yes it still does it with AC off.
I described it to a friend who drove it and he said it's just the engine running rich to help cool down the turbo once it's done some work. He also said it shouldn't do it at all when the engine has just started up, but that it's expected if the engine/turbo have warmed up a bit after spirited driving.
IF this IS the case, I'd be surprised if the 'thud' is meant to kick as hard as it does. Gonna investigate and test more of when it does/doesn't do it. Doesn't sound like anyone else's does this though, which isn't too encouraging.
OK after further investigation:
A) It doesn't do it at all if I start her up cold in the morning and just let her sit there idling.
B) When I was at the lights after 10-12 minutes casual driving (mostly 80km/h between town centres and then about 5 minutes of 60km/h.. so pertty easy going, barely boosted). I listened and heard/felt: car idling and there isn't actually any popping at all. I know what back firing sounds like. This literally feels and sounds like a miss... engines running fine and every say... 5-10 seconds it sounds like the engine simply misses a beat. Sucks. gonna take it to my mate and point it out to him, see what he thinks cos he only drove the car before i noticed and mentioned this sound, he might be able to tell me more if i knows what i'm talking about first hand. A missing cylinder isn't actually audible as a "miss" in the sound of the engine running, right? cos it misses thousands of times a second doesn't it?
So I'm at a bit of a loss to what this might be. I might rock up to the local gathering (ACT national museum) and have a few other 'line owner listen and tell me if I should worry or if I'm just paranoid.
Hmm.. sounds a bit strange, sometimes when idling mine will get a little rough.. but can even this out by just touching the throttle a little bit..
The RPM's should go up a little bit when the Aircon is turned on as the ECU should automatically adjust the idle RPM according to the power required.
You could try resetting the ECU and get it to re-learn it's timing as per the new fuel and so on and so forth..
I don't know about the whole "it's running rich to cool it down" even after pushing mine very hard it's still idling pretty well - maybe if you turn it off than back on it has trouble hunting for a idle RPM.
Get a couple of other guys to listen to it and see what they think - it's a bit hard to guess at what it is when we can't hear it..
Does the car have HICAS? what year model is it? When was it brought into Australia?
First post: Engine is stock cept the exhaust.
Yeah, I notice the more obvious engine activity while A/C cut in and out while idling.
Yep, gonna have a few locals listen to it, see what they think.
It's a 10/96 R33 GTS-T coupe with HICAS. Came into the country 05/04. In fact, looks exactly like ur car Links. Go the silver :P
i fink it's coil pack or spark plug or leak from exhaust or from air filter..
clean ur air filter dat's one thing u can do.. other stuff u hab to get check up at mechanics.. good luck with fixing it.
coz i had three prob with my car.. coils and plug and filter..
i hab to fixed all except to chane coils..
waiting for coils to come..
My car seem to hav the same problem (with a/c on is more prominent), but mine is a R34 GTT manual, 3" exhaust, air filter and new HKS plugs (range 7) because it happened with the old NGK plugs too. The funny thing is everything ran fine when the new plugs when in for a month then just last week I change the timing belt ("Power" Jap brand), the miss came back again. It usually gets more frequent misses intervals during the afternoon.
Anything to do with timing or coils? Not sure whether I need to reset the computer again? Appreciate advice
Newbie
Newbie
Guys Ive had my R34 for about 3 years now. Anytime I have issues with misfiring etc I look at the coil packs. It never happens when its cold only after 10 mins or so and the check engine light comes on.
I now just check the coil packs, have had to replace 3 in the last 3 years. Either Araldite them or just buy 2nd hand ones. It seems to be a reasonably commom issue, for me anyhow.
i got brand new splitfires Di !!! Must be something else i did notice my canon is leaking exhaust gas ses ,anywayz back to standard or quiter as I'm off to the EPA very soon waiting for letter in the mail !
OK So we checked out the coilpacks: they look fine. They are the original stock ones, but there are no signs whatsoever of the arcing, e.g. strange burn marks or whatever on the sides of the packs, or scorch marks on the internal of the engine.
So then we pulled off the O2 sensor and found that the car runs exactly the same with it connected and disconnected!! The reading on the sensor was a permanent ZILCH. My mate said that most jap O2 sensors operate between 0.4 and 0.6 volts, and that 0.5V is the reading that it is ultimately trying to maintain. He reckons the car is running real rich and may be in what he called "limp home" mode .. or something like that. We're gonna swap out the sensor for a new one and see what happens. From the sounds of things its a good thing to fix/replace anyway, even if it's not the solution for my misfiring. I'll post my findings.
O2 sensor didn't change anything with respect to the misfire at idle, but the car seems a bit more responsive now. The new sensor gave the measurements expected when it was hooked up. During the first 3 minutes of idling after hookup, there was no misfire, but then after a quick hoon, it presented itself again *sigh*
FOUND! Had it into the mechanics today. He said that when he adjusted the throttle position sensor, it idled 15 minutes without a single miss (and sounded much better too), but as soon as he went for a drive in it, it started again.
If I understood what he told me correctly: He attached an oscilliscope to it (and a lot of other things too) and said when he gave the throttle position sensor a tap it sent the signal absolutely spac and it misfired like crazy and then when he left it, it misifred at the intervals I've been seeing. So I'm ordering one tomorrw (he recommended JustJap, any other suggestions where I should check?) and he said he'd install it for free since he's got all his money for just diagnosing it. I've looked on eBay and even a Porsche TPS is only 40AU, which makes me hopeful that I'll get away with a secondhand one for maybe 30-50 at worst. I'll post again when it's replaced and I'm 100% it's solved. So everyone check ur TPS!
    • Forgot to update. I ended up removing it and found out that it's dead. The car seems to run better than it did, although I haven't driven it hard yet. Literally just a flow restriction.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
    • G'day ... first up, I very much doubt that's a resistor network (as used also for this job), but the part# looks right. The description of 'power module assembly' looks to be nissanese for 'PWM driven, ground switched, DC motor speed controller'.... the circuit in the schematic kinda infers that's the case... ...with the transistor symbol appearing in the unit described here as 'Fan Control Amp(lifier)'....being driven by pin20 on the HVAC unit,  and a feedback signal on pin19 from the motor negative terminal for some reason (might be motor fault detection, maybe they detect commutator switching to determine motor revs as well, I dunno)... but if they are  counting commutator spikes, a bad segment (or really worn brushes) will throw a spanner in the works... The motor itself will as said be brushed DC with segmented commutator, rated at 12VDC nominally ~ now-a-days I just unplug them, determine the positive wire, and hook them up to a variable power supply and find out how much current they draw, if they work etc etc ...you can also check for bad segments...ie; set the power supply up to feed 1volt @ 2amp max, then watch the wattage count as you slowly rotate the fan blower motor through a complete revolution ; any bad/dead segments will be clearly evident...some folks would just say determine the positive wire, and feed it battery voltage, and if fan spin, you've got a win...<grin>... well, at least that infers it should do something when plugged back in, and the HVAC unit commands it to run... and if it doesn't, you suspect the module, but you should check the PWM signal on pin20 is actually present, and if it is, blame the module ...
