  • Replies 303
Posted Images
You need someone with a colour printer at work that'd do the job.. :P..
If you go to Officeworks - sorry wasn't thinking straight - it might be cheaper than that and get it printed on A4 paper than cut it out..
Looks great mate - looking forward to the Trailer being released.
Edited by Links
Ed, there are already too many 34s on the cover, and besides, all photos of your car were for some reason not too responsive to the light.
Next cruise, I'll do a complete shoot of your car... you can be the cover image :D Just remember to polish her up...
Also, from now on there will be a 32, 33, and 34 contest for cover images~ I'll try to vary it from cruise to cruise.
Latest Update:
Just got off the phone with the two other guys producing this DVD; got the latest in terms of the stage we are currently at, what we need to do and etc. etc.
Anyways; the DVD is almost finished (the final version); the trailer is being made tonight and tomorrow; we are looking at a Friday night release (hopefully)! I haven't seen the current cut yet, but from what Menthu Rae says (who is extremely picky), Daniel has done an awesome job.
We aplogize for the delay but please understand we do all have normal jobs as well. Plus, this being our first real attempt we want to make it good...
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
