never seen auto's on dyno. Why? Is there a tech reason? :D
I've got an Automatic (tiptronic) Skyline and set it on the dyno. No drama's about it
p.s only got auto cos it was hard to find manual with the 4 door R34
dont think they exist..
Ever seen a 2000hp drag car on the dyno - they usually make about 3/4 of that value. To much trans slip to give accurate readings not to mention changes in auto trans fluid temps(varying viscosity etc etc) not good for dyno comps or tuning at high levels of horsepower.
we had an auto r33 at the sau vic dyno day yesterday. was ran in 2nd gear as the auto juggles the power rating all over the place apparently when left in drive. the manuals are done in 4th gear so what power rating the auto gets i would say add %15 more power cos of the 2nd gear ratio? does that seem reasonable ?
You can run a car in any gear and it should give comparable horsepower readings. ie a manual R33 should give about the same power readings in 3 as it would in 4th within about 1-2% depending on the dyno operator. You must remember that dynos measure the rate of acceleration under a specified load and Horse power is a function of Torque and RPM so while lower gears will give a higher torque than a taller gear the RPM of the rollers is less in the lower gears than the higher gears.
Now dyno dynamics specify that their dyno's are accurate between about 80 -140km/hr. So the aim of the dyno operator is to choose a gear that will rev between these points.
Thanx 4 the replys everyone, very useful, Im asking really what i would have to do to get a high HP street car (auto) to be efficient on a dyno as well. Is there options for making an auto box perform well on the dyno? Shift kits etc. Any ideas?
nope. coz as soon as they ramp the power up it kicks back to 2nd anyways..unless u have it manualized.. they'll always do it in 2nd gear for the autos. .... and they seem to strap them down harder than teh manual cars.. coz apparently the auto (car itself) can jump on the dyno from time to time.
autos are the ghey... too much drivetrain loss thru slippage. .. thats just my personal opinion but.
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
