Jay95R33 Posted June 20, 2002 Share Posted June 20, 2002 Does anyone know what ratio the standard diff's are in the R33 GTS-t's? And does anyone know if they changed them at all from the 1993's to the 1995's (within the series 1 range?). Splines the same etc.... for a swap over? Thanks J Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/ Share on other sites More sharing options...
Guest INASNT Posted June 20, 2002 Share Posted June 20, 2002 i think they r around the 4.11 ratio Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-19839 Share on other sites More sharing options...
whatsisname Posted June 20, 2002 Share Posted June 20, 2002 J, I'm 100% sure it's 4.11 I'm 99.9% sure the only change was when the A-LSD was released on the later series 2's. I also know the non V spec GT-R 4.11 diff' will bolt straight in Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-19886 Share on other sites More sharing options...
Jay95R33 Posted June 20, 2002 Author Share Posted June 20, 2002 G'day Matt, Thanks guys. Good to hear. J Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-19924 Share on other sites More sharing options...
Guest Impul 25T Posted June 22, 2002 Share Posted June 22, 2002 Originally posted by whatsisname J, I'm 100% sure it's 4.11 I'm 99.9% sure the only change was when the A-LSD was released on the later series 2's. I also know the non V spec GT-R 4.11 diff' will bolt straight in The A-LSD was an option for both series'........ only in the manual coupe though. Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-20604 Share on other sites More sharing options...
akira Posted June 22, 2002 Share Posted June 22, 2002 Hey Jay, On Ur compliance plate, there are the letters RC ( Mine says RC43 but most have RC41 meaning 4.11 diff ratio) I think 2 doors have the 4.11 diff as standard equipment and the 4 doors have 4.3 ratio as standard Hope this helps Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-20655 Share on other sites More sharing options...
akira Posted June 22, 2002 Share Posted June 22, 2002 Hey Jay, On Ur compliance plate, there are the letters RC ( Mine says RC43 but most have RC41 meaning 4.11 diff ratio) I think 2 doors have the 4.11 diff as standard equipment and the 4 doors have 4.3 ratio as standard Hope this helps Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-20656 Share on other sites More sharing options...
Jay95R33 Posted June 22, 2002 Author Share Posted June 22, 2002 Thanks for the info guys. Akira, interesting about the compliance plate - I didn't know about that. Mine says RC41. The reason why I was asking these questions is cause I have a mechanical Cusco diff in mine, and I was thinking about buying a stock diff and putting that in, then selling the Cusco one. But after chatting to a few people they have convinced me to stick with the Cusco. It might be a bit noisey on tight slow corners, but apparently the performace and strenth is huge compared to the stock one. Sooooo, I'm sticking with the Cusco. Thanks for all the info guys. J Link to comment https://www.sau.com.au/forums/topic/929-r33-gts-t-diff-info/#findComment-20694 Share on other sites More sharing options...
