Hey guys.
I am buying a GTR engine, and was wondering if anyone could tell me the differences between the r32 gtr engine and r33 gtr engine. Apart form the age difference is there any difference? Any physical changes? power or anything at all? Ohh and sorry but 1 last thing, do the v-specs have any more power thasn the standard engine in the r33 range? Any help would be greatly appreciated! Thanks
Cheers Mark
Edited by markjh27
Ok. Whatever i post, im getting it from the latest GTR special Issue of HPI. just want to clear that up now.
The V-spec (in the 33 at least) has the active diff and different ATTESA system. Doesnt say anything about power. But there was an N1 special which did have upgraded turbos, suspension tweaks better water and oil pumps. only a few hundred were made.
Both the 32 and 33 have 206kw@6800
torque: 32 = 353Nm@4400
33 = 368Nm@4400
redline: 32 = 7500/8000
33 = 8000
i personally dont know much about the differences, its all from HPI. This is what it says, and they know more than me as its their job, so it looks good.
enjoy
r33 engine has the larger crank drive for the oil pump, this makes oil pumps last alot longer as the engagement is alot sturdier. Everything else engine wise is the same from an internals point of view. r33 has pull clutch unlike th r32 which is push. Power wise the engines are the same.
yeah thats what i've read, the crank is a bit different for the oil pump. the pull/push type clutch is to do with the gearbox not really the engine...
but i have read that later R32 GTR engines changed to the pull type clutch? and probably the newer R33 crank.
yeah the latest r32s had the pull clutch.
The only real difference is the oil pump drive is larger on the 33 and you can always get the 32 crank modified to work the same way.
Re the water pump I had the same problem, the 33 water pump has an additional hole (slotted) that I needed to weld up, so the must be an extra bolt hole in the 33 block.
Otherwise all identical, nothing that affects power output.
I also saw that HPI article and I have never read such a load of garbage. Imagine comparing a 5yo to a 10yo to a 15yo engine by running them on a dyno, then claiming the newest engines are the best.
Crack the engine open you will find its all the same inside....which means a well re-built 32 engine will outperform a second hand 34 engine every day.
Late model 32's have the 33 crank , how do i know ? The 32 engines have different oil pick up strainer , its different where it mounts on the block . The 32 has a groove and it uses an 0 ring as a seal , the 33 is flat and it uses a gasket . I have had an engine with the earlier strainer , 32 water pump and the 33 crank and it wasnt changed i'm sure on that as the engine was original .
Duncan , i'm not so sure that the cil head is the same ( not saying its not though ) and the dumps are different . Overall though there is not much difference in all the rb 26's , the main reason for making more power in the 33 + 34 is the tune and more boost .
You are correct on the hpi crap , they say that the 34 turbos are steel wheeled as well , how would they know ?
Some guy was arguing with me about the 34 turbos , he said it was a well documented fact that they are steel wheeled because hpi said so , some people believe everything they read .
hey guys,
first of all thank you for your info. I was greatly appreciated. I have just bought today a R33 GTR V-Spec engine which is supposedly out of a 98' model. I don't know how to makje sure it's v-spec or if it's really 98 or a r32 model. Anyone know how i can find this out? it is out of a half cut.
Ohh and what motul ol do ppl use in these motors? Whats best?
thank you all for ur help.
Well they do have a steel intake wheels and ceramic exhaust wheels. My room mate bought a set off a friend of mine when he changed to 2530s on his 2001 Vspec II, as his 32 GTR spat its turbos.
yep all GTRs have steel impellor/ceramic exhaust turbos, except the N1 versions :D
wrxhoon I would be *very* interested to know if there were any head differences, I have never had 2 together at the same time. Thanks for the other differences you found, that is interesting....but of course none of them would affect the performance of the motor.
Yes there were differences in engine externals between 32, 33 and 34 but we are talking engine differences. External differences included turbos, dumps, exhausts, ECU tune, boost
You are right Duncan on the turbo bit but nur-specs have steel wheeled turbos as well .
I have had 32 +33 cil heads off the car but not side by side so i can only go on i have heard , thats why i said i'm not sure if they are the same or not . I never had a 34 head off the car so i cant say on that for sure .
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
