just wanna warn all you guys out there with r32 gts-t's. i had mine for 8 weeks, done basic mods, gtr bar, bar and plate cooler, adjustable suspension etc, 3 inch mendrel from turbo back, but nuthn of that has any bearing to what im gunna warn about. doing 130km/h's hour down a backstreet, backed off to 110, slightly pressed brakes and the front right brake caliper locked up. pulled foot off brake and repressed to find both front calipers seizing, locked on completely. i hit a parked car at 80km/h, 66 metre skidmark. but after some inspections(im a qualified mechanic) found ALL FOUR pistons on both front calipers seized up and locking brakes on. went to Tony Rigoli Performance to chat to Rob Rigoi and apparently that is the 4th time he's heard of it happening.one was his brother! so boys, be careful eh. its a big loss in the end,
Cheers.
https://www.sau.com.au/forums/topic/9291-front-brake-lock-ups-r32-gts-t/
we just finished fitting a 3 inch mendrel system from the turbo back. opened it up to see the results. very impressed for a split second there, but........guess when you look at it, it kinda wasnt worth it :P
as for the brake upgrade, why?? 4 spot calipers are more then enough for the moment. its only a stocker fellas. all ive done is rebuild all 4 calipers, fitted slotted discs front and rear, and used EBC kevlar pads. should keep me happy for a bit.
Thats a horror story mate! I hope your ok after a hit like that. The Sumitomo 4 spot's are found on numerous cars, including the GTR and 300ZX so the problem could also occur in those models too.
Theyre a bloody good set of stoppers and i doubt most people would consider upgrading them to anything short of a set of AP Lockheeds. Unless your doing trackwork there isnt much point really eh? :P
Anyway, that story is enough for me to get my brakes checked out!
Red17
The same brand of callipers can be found on subaru's, except the new sti's with the brembo's, toyota landcruiser and hilux's, the 200sx range, and pretty much any manufacturer who realeases a car with 4 pots as standard, sumitomo do a lot of OEM supplies..
  • 2 months later...
might have to sell it chewy, i just replaced the upper, lower control arms and the caster bar to try and straighten the wheel up, and the ****ers still no good. ahh well, looks like i got 12 months to fix it before i get my license back anywho.
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
