13.4 second 1/4 for your 'stockish' R33. (A how to guide).
gts-vspec,
You didn't have the wing on when you did the 13.5, what about the other times you went down?
And didn't you take 10% out of the mixtures while you were there too?
judd,
You should just PM Rhino, he's a WA boy so have a look for him on the WA side of the forum.
rev,
No I haven't bothered ever running with the wing on, apparently it does make a noticable difference, slower when its on due to the drag.
The only mixtures I've change is to take out some fuel at idle, nothing related to the power.
See'ya:burnout:
Judd,
Rhino's previoous best was somewhere in the mid 13's, so don't be too dishearted. Once your comfortable with the car you can start launching and shifting harder, you will see your times tumble.
See'ya:burnout:
Ive run my best times with no BOV
Will put one back on once i fix some problems associating it,
I dont get any lag..at all! Just puts a little extra pressure on the turbo between gear changes and sounds a little poofy!
Rev i think you need to do a few mid 13s to back up most of the how to do a 13.5 bla bla with stock bla blas, or maybe im just Jealous :D
I should be ready for a squirt next wednesday at kwinana for steady high 12s
I wish I was that consistant, but on my last time down most runs were under 14, which is good. My 60' times are getting better with 2.1's and 2.2's mainly.
Works Auto ran a 13.3 the other day, and he said that his MPH was higher and thought that it may have been becasue of removing his GTR rear wing. Do wings, if there not very high, cause much drag?
See'ya:burnout:
Guest Works Auto
Just adding my 2 cents worth here.
On ,y 32 i decided to stick with the stock BOV until it started leaking boost. But last night ran 17psi still not leaking.
It works really well , never gives any trouble and the mixtures stay perfect. its staying for a while now :D
40RCD ran a 13.4 @ 108mph with automatic trans, 15psi boost, avgas and toulene, timing advanced, 3 inch exhaust about 3 years ago before it got heavily modified. oh it was good fun on the streets!! :wave: wheelspun all through first into second for abit then took off. had many good race against my other mates VL turbo with the same mods.
rev210: i reckon you'll break 12s if you strip your rear seats to the boot :rolleyes:
i ran 13.4@103mph with full exhaust, airfilter (pod style no shield), bov, 1bar with EBC and stripped interior from rear seats to boot. everything else is stock including drivetrain, suspension and tyre pressure.
i believe a street car should run 'as is' without deflating tyre pressures or changing suspension setup :D
VISHES,
I agree with you about 'street trim' thats why I haven't put slicks on the car. Everything else I do is 'street trim' including the tyre pressure. I drove around after the drags with 20psi in my tyres, I just don't fang it around corners.
The 12 pass is there without stripping weight, the mph is high enough if I can reduce the 60ft to 2.0 or 1.9. That would probably require some better tyres, which I can't be bothered buying till these ones wear out, after all its a work car.
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
