13.4 second 1/4 for your 'stockish' R33. (A how to guide).
the 255's let down to allow side wall flex would do the 225's in over the 60ft. If we are talking the same rubber compound/tyre.
The inflation of 36psi will put the 255s at some disadvantage Vs 15psi. Then again 15psi might be too low if you are talking street tyres (not nitto's or mt's).
Guest MFX_R33
If the tyres are the same rubber/compound, then the tyres with less pressure will give you the most traction. Width of tyres does make a difference but not as much as pressure. A 355 trye at 30psi has the same contact area on the tarmac as a 195 tyre at 30psi. The contact area is determined by the weight on the tyre and it's pressure. So with the 16"s there is more sidewall to flex, given that the compund is the same over the 2, I think the 225 on 15psi qould be your better bet.
Jeff.
Atmospheric BOV`s might help more air to pass, but, having an Air Flow meter equipped car you confuse the ECU and undo any bennifits you could achieve.
I would recommend using a GREDDY plum back style, Which flows 2-3 times the air. It might not sound as good as the standard , but, the truth of the matter is the more restrictive your BOV is the louder it is.
Or you can get away with an atmospheric type when using a S-AFC as this is equipped with a function that momentarily sends a preset A/F meter signal to the ECU when the BOV is venting. No more kneecapping flames !
Agreements - Disagreements ?
boostd,
I'm not a fan of the aftermarket BOV on a stock turbo. Experience shows me they are often a step backwards in performance.
It is a superficial mod. It is totally unnecessary in the pursuit of a 13.4 second 1/4mile.
Flywheel questions
After the new flywheel went in did you notice an increase in fuel consumption? Also when crusing around town does the car tend to slow down more quickly when you back off the accelerator (ie feels like your towing a small trailer up a hill)?
I can see how a light weight flywheel would make the car go faster but how practical is it to do for a daily driver??
  Quote
Originally posted by riggaP
Flywheel questions
If you have this problem make sure you get a full exhaust system, deffinetly makes it a smoother ride (also better midrange power).
Benm: Dude wat are u talkin about. This has nothin to do with exhausts, the fact that he has a lightened flywheel means the car will rev quicker hence will also drop revs quicker aswell. It may give the feelin that the car is slowing quicker to some.
As i said, with a full exhaust system the engine will breath easier and wont 'slow down' as much when off the accelerator, its 1 of the first things i noticed when swapping my stock dump/front pipe to a 3" custom.
the lightened flywheel will decrease the time it takes for the engine to speed up or slow down (to a far lesser degree).
I have one of the lightest flywheels around @4.8kg and it's nothing but a pleasure to drive in traffic. My entire car is based on being 'comfortable' over long distances and in heavy traffic for long periods.
Many a slow-ass-know-little will tell you that the lightened flywheel is this or that and poo poo. Kick them in the head and move on, if it's your friend then kick them softly in the head.
  Quote
lol. This was actually a guy who claimed to be a race mechanic at an autobarn store?? Some of the stuff he said made sense.... but he denied the existance of the boost solenoid on R33s tho, said something about the second cam kicking in at 4700.
nigasnt
Yeah i know... he also said something about his uncle being on the 32GTR bathurst team??? Thats when he lost me.
Altho some of the stuff he was saying made heaps of sense... prolly coz i aint know shite...
    • Hi ๐Ÿ™‹โ€โ™‚๏ธ. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? ๐Ÿ˜ƒ  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this ๐Ÿ™
    • Hi, Marek here ๐Ÿ™‹โ€โ™‚๏ธ. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
ร—
ร—
