13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Im using the standard ECU and the Air/Fuel ratio's are all over the place at the end because the ECU is going into rich and retard mode. We tried dropping the boost down to 10psi and this was still happening
:P
Got my car on the dyno the other day and it was making 173kw on 12psi and 181kw on 13psi. I thought this kind of power was ok for the mods i have. So rev210, u got any ideas as to why my terminal speed is slow?
My boost was actually bleeding from 12psi down to 9psi?
Could this have been the reason?
I recently got a new boost controller from simark87, and it seems to be holding better.
Sorry bout the stupid questions, its just that im going down to the drag strip in the next couple of weeks and dont wanna be stuck in the 14's again.
P.S: Check my post further up for mods and time etc.
Thanks for ur help
Mike
:P
Hi Mike,
I think basically you are not making the 181rwkw at the strip for some reason. I suggest the 'hot' air your pod is drinking in when you run. Did you dyno with the bonnet down? Get a cold air partition made and it should be fine mate.
  • 2 months later...
  • 2 years later...
hi mate interesting post ,
i couldnt open up the link to your time sheet what mile per hour and 60 foot did you run ?
also you say the timing was altered , was that the camshaft timing , ignition timing or ignition map?
good read, very fast for minimal mods.
I always keep an eye on times and other things and one thing i noticed in particular was the difference in times lots put up. More so when the 60fts and mods are the same. Example below
HKS-R33,
My old R33 gtst had an exhaust and pineapples only (everything else stock) and ran 13.8's pretty easy on 205's. Get a heat sheild and see how you go.
My mates R33 GTST with full zorst, cooler, 14-15psi, splitfires and a 2.060ft ran in a 13.75@104mph. Yet yours got 13.8 with zorst only (not boost controller etc?) what 60ft was your run. Surely it will not be much greater then 2.0 so i wonder where the time is being made by you, or perhaps lost by my mate? What was your MPH on these 13.8 runs?
well i haven't got a skyline, but in my chaser i ran a 14.06 @103mph with a 2.38 60ft time running standard SMIC and running 8.5psi (9.5 on the spike). I just couldn't get off the line even with the auto as i had bald tyre :(
I'm having a guess with a 1.8-1.9 60Ft mark with the same mph i would be in the mid 13's
Once again, I've sat and watched an auto chaser with a cooler and cat back zorst (i think, could have been turbo back), auto as well pull consistent low 15s/high14s at around 97-98mph.
So i wonder yours got to 103mph so stocko.
Either way. My R34 GTT (at the same track as all the above times ive mentioned) scrapped in a 14.0 @98mph. This was with a 2.0 60ft. So its about as good as its going to get. boost increase and cat back exhaust. Thats running 19s up front and an unsheilded pod.
I just cant work out the difference between times. Ie chaser pulling so much MPH where every other one i have seen its dead on my MPH (about what to expect with similar torque and power figures)
hmmmmm....
hmmmmm....
the 13.8 was at 101mph, 2.1 60ft.
98mph = lower power than my old R33 gtst at 101mph terminal.
gear selection and shift point can kill off some time if you get it right.
im running stock turbo with safc2 exh,pod,fmic,any idea's on the tune settings example neo setting dec air blahblah blah,i ran 14.2 a couple of weeks ago massive wheel spin with .55 sec reaction ,2.16 60ft and 98.94mph seemed to run out of legs early.anyone help, not happy
The SAFC should be tuned with a wideband and or dyno. can't just copy someone elses settings.
the Dec air isn't needed unless you run an atmo BOV.
2.1 60ft is ok. The Pod is unshielded? if so that doesn't help.
yeah unshielded with intake pipe just need to find somewere good to take it was runnin 235/45/18 old things .thanx man
  • 1 year later...
hey there rev just another kiwi here i got a r33 s1 1993 auto and also trying to get max outa standard ecu and standard exhaust yet to take her in for second dyno . She got 150 kw at wheels with 6.7 psi blocked radiator and a smallish pod filter and no cat then got new water pump racing cam belt and that replaced and took her to the quarter. She got 14.9 @ 166 since then ive taken all the turbo restricktors of such as boost restricker 2 stage standard controller unplugged restricker pipe of back of turbo removed and replaced with free flow front of intake rubber pipe replaced with alloy pipe 10 inche greedy pod filter and r32 wastegate actuator hope to take it to dyno in next few days then to the quarter again and hopefully i beat u and btw i cant seem to find ur time slip :) and yea standard tyres are 205's!!! i use 225's on the back and 205's on the front and my free flowing standard exhaust lol be good to see what she gets =P
There is a huge difference between 14.9 and 13.4 man! In NZ I have not heard of anyone getting anywhere near the results they get in Oz for whatever reason, so don't hold your breath. Managing a 13.xx is a worthy result on street tyres here.
With an auto you may be struggling that bit more, too...
Edited by Lithium
Im going to keep running on street tyres untill its ultimately clear that i cant get anything more out of it.
Did a few 13.7's @ 99-100mph in my R33, but since then i have replaced the stock dump pipe with a custom :as big as will fit" jobbie, and had a road tune VIA SAFC2.
Still running stock airbox with APEXi Panel filter. Seems to work just fine for me too.
Is shielding the POD really necessary? I was told by a 'knowledgeable mech' that you just starve the intake by doing so; what you may gain by having slightly colder air you lose with another restriction.
Shielding the pod is a great idea - the majority of air will be coming from the front of the car, the ambient heat from behind the filter basically acts as a contaminant to your nice cool air. The front of your car has a huge high pressure zone when you are moving, so long as you allow a path from there to the filter your car should not be starved in the slightest.
I made up a perspex airbox back when I had stock turbo, S-AFC etc and checked the AFM signal on a few runs before and after to see if it dropped or rose and I'd say if anything the airflow meter felt that there was more air flowing through. Possibly denser air, or that the margain of error was greater than the difference in flow :D
Mr Rice - I had the stock intercooler when I did it, it was a prick but still possible
Edited by Lithium
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
    • I know this is a super old topic, but what ended up being the problem?
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
