13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Shielding the pod is a great idea - the majority of air will be coming from the front of the car, the ambient heat from behind the filter basically acts as a contaminant to your nice cool air. The front of your car has a huge high pressure zone when you are moving, so long as you allow a path from there to the filter your car should not be starved in the slightest.
If the air is flowing from the front how is hot air from behind going to 'contaminate' the air flow into the POD?
I'm not saying you are wrong just wondering.
It could be that dyno results which 'prove' a shield is necessary, only do so 'cos the car is not moving (on the dyno) and so no 'cool' air is flowing from the front - w/out a shild the POD is just sucking in air from 360 deg around it which includes hot air around the engine. On the road it won't be like that of course with the 'cool' airflow from the front?
Edited by Battery_backup
so lithium how much rwkw u make at 6.7 psi???
The hell kind of question is that? I am pretty sure it made around 180rwkw on 7psi during a very early tune session, ran low 14s like that. I can't run any less than 12psi with the current setup - drag season is coming up, could have a friendly manual versus auto comparison :yes:
Sorry i thought this was about standard times and ratings etc sorry if i got it wrong
Ill do it! Perfect. Fun fun.
line up a v8 with a c4 transmission and same rw power and see what happens
I think you'll find that a typical V8 drag car automatic isn't setup quite the same as what the auto in your GTS25t is, hardly apples for apples. You Best tell the funny car and top fueller guys to get rid of their clutch setups and go torque convertor! Of course you CAN get your Jatco rebuilt to handle some decent power and stall/shift more aggressively so it actually does suit drag racing....
so ur setup only made 20 rwkw on my standard setup lol
I'm not sure what you are getting at or trying to achieve here, if you have something you need help with specify it please. It'll be good to see how you go with the auto - never said it won't go fast, it just could be a challenge unless you have or are going to get it modified to suit what you are doing.
Just for clarifications sake - you made 150rwkw on 7psi with stock turbo and I made 180rwkw on 7psi with stock turbo, and you somehow come with a comment lolling I only made 20rwkw more than your stock turbo? Given I made 30kw @ wheels more than you on the same boost with the same turbo, I am actually struggling to work out what you are going on about.
Edited by Lithium
Ahh right sorry, when I said "I can't run under 12psi with the current setup" I meant with the GT3076R vs the stock turbo - I couldn't run 7psi if I wanted to with the bigger turbo.
Edited by Lithium
how bout 13.061 on stock turbo...stock ecu....only exhuast/fmic/boost......on street tyres as well....2.00 60ft...
Not un-realistic if you get a good run and launch.
It may be a high goal, but im aiming to get as close as possible to a 12.999999 with stock ECU and bolt ons and street tires.
When im convinced i cant do any better only then will i try on some semi slicks.
If you can nearly do it, then so can i :D
yeah....super close to my goal....cant help but be a little disappointed it didnt crack the 12.....but theres no way i could launch any better absolutely no tyre slippage, it just stuck....tyres couldnt hold any of 2nd....chirped 3rds....and the rest is pretty straight forward....
best time on my other r33 was a 13.08 on some pretty used drag slicks....launch was a bit better...1.911 60ft with wheel spin....slipped part of 2nd....chirped third.....trap speed was 4km/h off ^^
but a 12 is possible....bloody difficult....the rest of the runs on that night were around 13.3-13.5....poor launching by comparison...
Interesting..
Only thing i will suffer from is horribly poorly prepped drag strips :D
Not quite the money around down here in NZ involved in the strips. But hey, just a handicap eh? :D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
