13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Back on the PCV valve catch can subject, the PCV valve is only open at vacuum and shut at any boost pressure, so why block it off altogether as I thought the catch can is mainly necessary while under higher boost and not general cruising.
All you ever wanted to know about PCV - http://www.hastingsfilter.com/engineering/.../tsb_94-2r.html
Why have ANY crankcase vapor entering the manifold I say?
  Quote
I agree.
Your oil collects condensation overnight, which is the first thing to evaporate when you are warming up your engine. I don't like to come on boost when my engine is cold so all the crap would be going thro my engine(with the PVC valve operating). I have already experienced the following effects by blocking off the PVC valve- Cleaner oil, cleaner plugs , sh*t tins better fuel economy, no condensation coming out of my exhuast, cleaner intake system. from what I can see it does nothing at all to improve your engine just pollution control. I found a small screw fits nicely into the PVC valve and still looks standard.
Anyone got a pic to describe this mod? Ie where you have put the screw? roughly?
Boostd: do you need to have a catch tank or can you just do the screw mod with similar results? PM me if you dont wanna post this info :)
Thanks :P
Make sure you get one with two nipples, a level meter and a drain plug. Also the nipples should direct the air/vapour almost directly onto a metal plate, have a look inside one and you will see what I mean. I have seen some cheap cans that don't have this and fail to separate the oil and air properly which causes the filter to get blocked very quickly.
  Quote
Originally posted by rev210
the highflow will help and so will the low ratio diff. Maybe 13 flat like you said if you can leave the line quick enough.
So you think if my Apexi speed meter is reading flat 13's then it should be correct for the type of mods ?
with the stock turbo the best time i got with the auto was a 13.59 then i installed the T3 / T4 combo and it went down to flat 14's.
Then i installed the manual 5 speed and it went down to 13.02 13.02 13.10 13.28
The dif ratio helps heaps because i get to wind it out in 4th heaps before the end of the quarter
  Quote
No not necassarily. I know of people with 12 second readings who can only do low 14's. The accuracy varies, on the whole it is not comparable at all to the real 1/4mile.
For the modifications you have I see a 13 second flat or a low 12 comming all things being right on the night (they seldom are).
Go race and find out.
Rev's right. The one thing the Apexi speed meters don't take into consideration is wheel spin.
You can sit in one spot and bag the wheels up, and once they wheels have done 400m worth of rotations it'll give you a time :P
  Quote
When i do my quarter runs & 0-100 runs i DONT wheel spin.
I find i get better launches taking off clutch spin on boost and floor it once i feel im gettin enuf traction
  Quote
Originally posted by qikr33
Hey guys just ran 13.7@100.6mph at willowbank r33,3"exhaust ,pod filter (no shield) 10 psi,18 inch wheels 235,40,18 optimax fuel,2.00 60 ft .Any questions just ask
Thats what i like to see. Someone without huge mod pull a decent time. Well Done!
Is the zorst cat back or full?
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
