13.4 second 1/4 for your 'stockish' R33. (A how to guide).
Well then rev210, if you done a 13.3 with a 2.3 60ft a high 12 will be closely within your reach with some decent tires for sure :burnout:
Great work Motox :) Your time is simply brilliant considering you only have a catback zorst and boost upgrade. What size/brand tires do you use? I will be very interested to see how your upcoming cooler upgrade will affect your ET
I think i have ended up spending the same since I bought a FMIC and Apexi PFC (both can be got thru Nengun.siteblast.com for a total of $2500) but I didn't get the following parts listed in first post:
* Diff Cradle kit or 'pineapples' , the Whiteline kit No. KCA349.
* Ogura Lightwieght flywheel 4.8kgs.
* Ceramic puck sprung clutch and stock pressure plate
* Wrapped turbo to intercooler pipe (DEI thermal tape).
did 12.992@110.16 on road tires.....found the PFC better base (although I understand you did swap emanage for SAFC)
good stuff! Excellent work on the standard turbo too.
The 60ft times are real good for road tyres. Gezz 1.9, I could only dream of doing that time on the 205's , would give me an easy 12.8 if I could get that.
Post up the time slips when you can we need more evidence that the R33's aren't just big whales. :)
Guest MFX_R33
4 Doorz, what tyre pressure were you running also?
You were running normal street tyre pressure in yours weren't you Rev, if you let them down to about 12psi or so, your traction would be heaps better, and your 60ft will lower dramatically.
Jeff.
Guest MFX_R33
Basically the larger the surface are of the tyre touching the ground the greater the traction. The surface area of the tyre on the ground is basically the weight on the tyre divided by the pressure in the tyre. eg. if there is 12psi (12 "pounds per square inch") in the tyre and say there is 600 pounds of weight on that corner. Then the tyre will distort until the entire weight on the tyre is spread over 600/12= 50 square inches. If there were 30 psi in the tyre then the contact area would be 600/30= 20 square inches.
You can see that lowering the pressure GREATLY increases contact with the road, which increases traction.
Jeff.
Guest MFX_R33
There are other factors that come into play, like side wall flex, and tyre heat. The more the tyre distorts, the more the tyre will heat up which will work against you, but you are only talking about a very short period of time, and I am not an expert, but even if you don't lower them as far every psi of pressure you drop has a marked improvement on the contact area. This is why Drag cars use extremely low tyre pressues (also have soft sidewall's as well).
Jeff.
ran mine at 19spi left and 14.5psi right, last time (13.3 & 2.3 60ft). I completely stuffed it up when I let them down.
Normally I run 19psi in both I just misjudged.
12psi is too low for a street radial. A bit low for a slick as well.
MFX...if you run radials that low, the centre of the tire (which you see from behind) actually starts to raise up and the edges form two "bicycle tires"...you will end up with a not as much traction say as at 19psi. - Drag slicks are built to take 12 psi while road tyres are built for higher pressure, I think at least.
I am using some cheap federals I got with the car 235/40 on 18in. Was running them at 27 psi for 1st run then 25 for sec run.
My car was dynoed 192 rwkw by Gavin Woods (and ran a 13.2) but since then I have changed the tune a fair bit to get times down
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
