Hey Guys
Im confused about fuel pumps. I know i could just get a 044 and be done with it, but i dont like the issues that might occur if its installed wrong (last quarter tank pickup) and also the noise that it might make. Also, since ill be mounting it in tank, it means that the factory bracket will be mangled and itll be harder to put back to stock if i ever need.
Im not really considering 2nd gtr items cause of the hassles that might come with it (not much warranty, old etc)
I want to get a fuel pump from nismo or tomei. Price wise theyre similar. $340 - $360 for rice brand vs $ 310-$330 for bosch. Take into account that you dont have to modify anything for the jap brands, the jap brands will probably be cheaper if you take it to a mechanic to get installed.
Nismo's specs are
246 liters per hour at 2.94bar
Tomei's specs are
248 litres per hour at 3 bar
Bosch 044 specs are
200 litres per hour at 5 bar
My power target is around 250-270rwkw (probably with a gt-rs or similar)
So for that i need 6 X 550cc injectors (just to be on the safe side)
So that comes to 3.3L/min or 198L/hour (max the injectors will flow)
Assuming fuel pressure is 2.5bar and a gt-rs is run at 19psi, the total psi i need is 55.75psi or 3.8 bar
Out of the 3 above, only the bosch meets my requirements as it has the flow capicity as well as the pressure capacity.
So i guess what im asking is:
Is it still ok to get the tomei or nismo fuel pumps?
I mean, itbmils has 300kw with the tomei one (the gtr one i assume which is 276L/h@3bar)
Initially i thought it was just the flow i needed to look at, but with the psi rating as well, im confused.
Are my calculations totally way off (if i run 19psi of boost, do i need an extra 19psi of fuel pressure?)
Anyone have any thoughts?
my advice is get the nismo pump. it will go straight in. even plugs straight in (ie zero re-wiring needed), and has the sock already on it, come with a new tank seal too. and it will comfortably support the injectors you want to run, at the pressure you want to run. worth the extra money for piece of mind imo.
  • Replies 40
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
