what about the internals used - forged internals will read higher knock - yes ?
this is especially so when the engine is cold.
I get readings in the 40-55 range on my R32 GTR - but dyno testing show no ping (thank god!!)
I've spoken to guys that have built and raced GTRs for many years - and the answer to this question depends on many factors. So I guess - the correct answer is - it depends
Get your car on a dyno – that's the only way to tell for sure (AFAIK)
Forged internals won't read higher.. Maybe if they are running super sloppy clearances, if that were the case the motor wouldn't last much longer than 25,000km's.
The knock sensor works off various frequency's..
I have forged pistons in the 3ltr that run on the sloppy side, to Wiseco's 24+psi/race spec. They see a max of 10 on start up, once idling and you can hear the pistons slapping away, knock is 1.
When reading knock levels I think the trick is to watch the graph, under acceleration it will rise up and hold fairly even, ping or detonation is when you see sharp little spikes. If yours is rising to 45-55 and those values are consistent, i.e no spikes then there's no need to worry.
Also remember a little spike here and there won't hurt a fairly stock motor, push 300rwkw+ through it and its a different story.
Edited by Cubes
yer my car will idle at 3-7 but a WOT can get up to 25-30 and have seen it get to 42 max when backing off mainly was tuned on a dyno
you'll find that what you have just stated is pretty damn spot on
I have wiseco's too - not sure on the clearance - but it's VERY niosy @ start up, and I get higher knock readings (still under 50 tho)
good advice - I have not looked for this - but I think I'm OK
well - I am pulling 300awkw - so why is that different (knochk is knock - right) ?
Its interestering you get high knock readings on start up, I know of an other R32 that on startup spikes to 50 or so. Why it does this I don't know, it shouldn't but it does.
I have heard some VT Commodores ping on start up.
Probably just a bad ignition timing and rich cold start afr mixture causing a rapid uneven burn.
Detonation is detonation but when you make more power you have higher combustion pressures, as a result a little detonation is much more likely to damage something. Exactly why those little old ford lasers can rattle along for many years without cracking a piston. :D
mine registers about 30-40 on startup
I reckon its something to do with the starter motor on the flywheel
Engage that while the motor is going, I see about 40 knock if I do that
OK
let's take this thread in slightly different direction
is what the PFC reads as knock actually detonation ?
WAIT !! before you answer ....
I have just had a power run done this morning - and one of the things I asked them to look at was knock. My PFC will sit @ ~40 all day - even under light load and low boost, but I have no signs of detonation (or so I'm told). This has been checked and rechecked by three different workshops on three different dynos and three different days.
if the man with the head phones on says – no ping – then I happy with that :(
My understanding is that the knock sensors will pick up ANY noise – and translate that into a reading on the PFC hand controller. This supports my understanding that if you have forged internals with large clearances – you'll get what the PFC picks up as knock – but it's not actually detonation – it's just a noisy engine.
I had an old 323 BMW that had the same thing once.
I have weisco pistons – and I do no know what clearances where used – but I do know that I can hear the forged internals – even once the engine is warm. So if I can hear them – so can the PFC.
This is all just my opinion, and opinions can be changed – so I'm happy to hear evidence to the contrary.
I have wisecos @ 87mm.. i don't really hear the piston slap, and the motor doesn't sound any different once warmed up. My knock gauge on the pfc floats around 0-25 while just driving around normally. No abormal knock value upon startup.. my guess is around 0-10 on the start. haven't gunned it yet on the new motor (no tune)
so - I'm guessing I have a loose motor
clearance was set by Marty White from John White Racing up here in Bribane. They also did the hone and deck of the block and a port and polish (reco) of the head.
He does the work for Theo W - so that was good enough for me (yes I spoke to Theo before going to him)
Might just be an 'over active' knock sensor. Picking up frequency's it shouldn't or something?!? :P
On that note now the warmer weather is here I can't actually here any knock. I had a listen this morning.. No Slap, water temp was 24degree's before I had started the car first thing this morning.
Last winter some mornings I saw water temps of 2degree's. :D
Edited by Cubes
i havent noticed much more knock since air temp's have increased. if anything they are a little better. i dont get any knock on startup. i think knock of over 100 ish is "detonating" as ive never heard mine ping on the road. only time ive ever heard my car ping was stock everything and i ran 1 bar (bypassed the actuator by accident) and then it pinged its ass off
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
