Have the following items for sale:
Brand new R33 Series 1 Carbon fibre bonnet for sale never used still in box $700
same as the one from carmate
Brand new r33 Top secret style flush bootlid which sits flush with the sides of the car good if you like the wingless look. $400
Greddy Single Pillar mount Brand new $50
Adjustable rising rate fuel regulator anodised in blue color with a gauge on it to read the pressure has been used in my car before $50
Custom boot install including :
kx600.1 Monoblock kicker amp $400
15inch L7 Solobaric Subwoofer $450
kx 200.2 2 channel kicker amp $200
parametric equaliser $100
Or the whole stereo package for $1000
This is a custom boot setup installed by audiocom and cost me almost 4k in total so this is a real bargain.
i am located in perth and i am able to send interstate if required
Pictures attached
Edited by shoeman
Yes the carbon bonnet has fiberglass laid underneath it. and if your car has series 1 lights and grill it will fit the car
Sorry i cant provide any pictures of the actual bootlid due to the fact that it is wrapped up in alot of plastic and padding that i would have to remove but it looks exactly like the one shown in the picture except the fiberglass is in white
bonnet sold
and i will check postage tommorow im not sure how much the enclosure weights but the subwoofer alone is very heavy so maybe around 200 anyway check tommorow yes it comes with all the boxes and moulds
Pictures attached
hello there
I have a r33 series 2 GTS-T.
do you sell the
1. front lip
2. rear speaker bracket
3. the cover that covers up the battery compartment in the boot
please let me know. thanks
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
