  • Replies 80
Posted Images
No prob's-just wish I could help out again,tho'! I know Sinista is taking a much needed break,but I can't say if WhyTry/Goran is up for it. G;where's your car at?
gorans car is off the road, otherwise he'd already be booked in for the 12th of dec :P
thats my formal...but im goin in some caddy now ahh bloddy dates n stuff
I only need one car for the 24th, but everyone is welcome on the 12th
By the way I think I PM'ed OZGTR32 about the 24th, but I think i F***ed it up so I will do that again :D
Thanks alot everyone for this, you're all legends :blink:
  • 4 weeks later...
Hey guys,
Just Posting to inform you guys of a change of plans, The cruise will start from 12 Allyn Close, Amaroo in Gunghalin. We will meet up at 5:45ish to leave at 6:00ish and crusi through wherever and rock up at the Musuem at 6:30ish. I'll PM everybody I think is coming with this info.
PS. If anyone has mates with skylines that aren't on the forums or mates with people that don't go online much tell them they can join in.
PPS. I will need 3 cars for people to actually go in, I'm not fussed, But I would really like to give the girls a bit of a show, nothing stupid, just some power ;) i.e. GTR's, or quick GTS-T's just tell me if you don't mind taking a couple :)
PPPS. I will grab the numbers of people giving lifts, if thats allright, just in case :)
Cheers
Reece
Hey guys,
It's getting close and I was just hoping for official conformations for the formal cruise :)
So far the people that said they are coming are (if everything goes to plan):
race_snooze
chintami
NathR32
SkyGTRline
Frink
Stevie
SKYLVIA
Terminal
Slither
ib6ub9
R31DET
Just wanna get some confirmed cars to take the formalites aswell,
If anyone else is coming just post or just rock up ;)
Cheers,
Reece
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
