hi all
Ive just finished rebuilding my engine and got the car back on the road (now its off the road again cause some f**ktard ran into me :@) but I noticed that when I shut the engine off, there is a distinct hissing noise coming from the front left side of the car. I have checked all vacuum lines etc (cause thats what it sounds like) and cant find a fault.
Has anyone had the same problem or does anyone know what it could possibly mean?
Cheers guys
https://www.sau.com.au/forums/topic/92973-hissing-after-shut-down/
My car has similar sounds when you turn it off... it'll kinda hiss for a bit like there is a pressure releasing..
Makes a couple of other noices, ticks a bit than settles down and stops after 20secs or so.. I've got over it as I don't think there is anything wrong I think it's probably just the engine cooling..
Exact same thing on mine.. After a while the faint hissin noise goes away..
must be a series 2 thing..
but ive only got the standard nissan turbo.. well so I think anyways.. but the only thing is it wasnt doing it before the rebuild (forged rods and pistons + balance).  Is it anything to worry about??
mine did the same thing when I had the standard turbo.
Like a hiss whistle. I wouldn't worry. If your engine is running ok, then leave it be.
Mine is stock except from exhaust.. it still does it.. I wouldn't be too worried..
No need to worry.... as a few of you had said its just pressure release coming back through your pod. You can just sort of hear it if you have your standard air box in there, but its no where near as noticeable.
I even had a vtech civic that would hiss out the pod when you switched it off... No need to stress guys.
On the topic of noise's any1 have this on their car
After i got GFB Stealth FX BOV fitted i now can hear my turbo making a winding noise
not air suction noise. cant really describe it but i've heard the same noise on a WRX sorta like a humming only when im on boost sounds pretty cool. just wanna know if its safe
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
