hi all
Ive just finished rebuilding my engine and got the car back on the road (now its off the road again cause some f**ktard ran into me :@) but I noticed that when I shut the engine off, there is a distinct hissing noise coming from the front left side of the car. I have checked all vacuum lines etc (cause thats what it sounds like) and cant find a fault.
Has anyone had the same problem or does anyone know what it could possibly mean?
Cheers guys
https://www.sau.com.au/forums/topic/92973-hissing-after-shut-down/
My car has similar sounds when you turn it off... it'll kinda hiss for a bit like there is a pressure releasing..
Makes a couple of other noices, ticks a bit than settles down and stops after 20secs or so.. I've got over it as I don't think there is anything wrong I think it's probably just the engine cooling..
Exact same thing on mine.. After a while the faint hissin noise goes away..
must be a series 2 thing..
but ive only got the standard nissan turbo.. well so I think anyways.. but the only thing is it wasnt doing it before the rebuild (forged rods and pistons + balance).  Is it anything to worry about??
mine did the same thing when I had the standard turbo.
Like a hiss whistle. I wouldn't worry. If your engine is running ok, then leave it be.
Mine is stock except from exhaust.. it still does it.. I wouldn't be too worried..
No need to worry.... as a few of you had said its just pressure release coming back through your pod. You can just sort of hear it if you have your standard air box in there, but its no where near as noticeable.
I even had a vtech civic that would hiss out the pod when you switched it off... No need to stress guys.
On the topic of noise's any1 have this on their car
After i got GFB Stealth FX BOV fitted i now can hear my turbo making a winding noise
not air suction noise. cant really describe it but i've heard the same noise on a WRX sorta like a humming only when im on boost sounds pretty cool. just wanna know if its safe
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
