hey;
Car Info:
S1 R33 Skyline Rb25det 100,000km+
Rb20 Turbo
FMIC
Air-Filter
Exhuast
EBC
Ok so here is my problem, my car was missing when i was turing on boost and running 0.8bar (started to happen about 1-2mins after running the car hard with boost on) with the ebc and running stock boost the car would not misses, i would run it hard all the way to redling and it wont have a problem;
So this weekend i change my plugs as i am running in a drift event this week and i need to be able to run boost.
Now i put normal Copper plugs, and gap them to 0.6; Taking it for a test run the car started to misses in every gear above 4000rpm on stock boost, with 0.8bar the car misses as soon as it hit 0.8bar on the boost gauge.
So i took them out and regap them too 0.8 and it has the same problem as above,
Now i check my old plugs they were gap at around 0.5.
I am majorly confused because before i change the plugs it would only miss under the condtion of 0.8bar of boost now it happens under stock boost.
What else could the problem be and how can i check if it is that, i will be taking the car to the mech 2morrow but i wanna get an idea before then
Thanks Michael :D
https://www.sau.com.au/forums/topic/92974-miss-firing-problem-plz-help/
ok
Today i replaced my new spark plugs with my old platium plugs (which had only done 20,000km)
THAT FIX THE PROBLEM!,
IT NO LONGER miss firers on stock boost BUT
when i turn boost to 0.8bar the car MISS firers from only about 4000 to 5000rpm THEN it just stops and goes all the way to redline without a problem.
apart from that 1000rpm the car feels fine, goes hard and doesnt feel like its losing any power (and this is backed up by the figures i see on my blitz power meter)
im SOOO CONFUSED!!!
the stock ecu has excess airflow protection which you will most certainly hit running 0.80bar boost. try it at about 0.60bar boost and see if you get the same problem. the stock ecu picks up too much airflow via the airflow meter and cuts the timing, which results in flat spots
mate your going to have to upgrade ur ignition system. Split fire coil packs are great for skylines with some boost. a lot of people say that thestandard coil packs can handle a lot of boost. I personaly dont believe that cause as soon as i boosted mine to 10 psi it was missin and back firin constantly. Got the new packs and problem solved. But there not cheap!!!
My R32's running 1.1bar with a VG30 and didnt missfire ever, still doesnt....and thats with the standard coilpacks, the only time it started was when my spark plugs basically disintegrated, got new platinums the the right heat range and bobs ur uncle she's a goer, still no missfires and can run more boost if need be. (dont want to though) but do as paulr33 suggested....
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
